Thread: abs pump
  1. abs pump
    Dec 2008
    from the day i bought the my car (a4 1996 1.9tdi 110 afn) i had a creaking noise come from the ABS pump every time i braked, so ive just this morning put a second hand ABS pump on it, but its still the same if not a little quieter? does anyone else know what it could be? ABS sensors? or should i just bite my lip and go and buy a new unit? can someone give me some advice? thanks!
  2. Re: abs pump
    Jan 2009
    towcester northants
    check wheel speed sensors
    if no faults/lights on abs try pushing abs sensors home ie push abs sensors inwards with hand
  3. Re: abs pump
    Dec 2008
    ive just noticed aswel, when you spin one of the rear wheels the ABS pump goes crazy, making loads os noises, is that right? or does that mean the rear ABS sensors are shot?
    thanks
  4. Re: abs pump
    Jan 2009
    towcester northants
    check sensors on diag machine
    it may be a sensor or a rotor fault but your abs light should come on if faulty
    try cleaning rotors first
  5. Re: abs pump
    Dec 2008
    Quote Originally Posted by towcestervag View Post
    ok, is the rotors the spline things near the back of the disc? thanks
  6. Re: abs pump
    Jan 2009
    towcester northants
    yes
  1. Replies: 9
    Last Post: 17-01-2016, 03:08 PM
  2. Question ABS Pump
    By rugerrog in forum Polo - Derby - Lupo - Fox
    Last Post: 01-09-2008, 09:29 PM
  3. pump
    By recodes in forum Golf MK4 - 1999 - 2004
    Last Post: 30-03-2008, 12:11 AM
  4. Air con pump
    By mmcconville in forum Passat - Archive Topics
    Last Post: 10-01-2008, 05:09 PM
  5. Vacuum pump (tandem pump)
    By audi_130bhp in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-11-2007, 12:44 PM
