Thread: Slightly unusual engine noise & servicing
  1. Slightly unusual engine noise & servicing
    London
    Hello all,
    Firstly, thank you to all the posters for their help so far - saved me a fortune with my leaky pollen filter and some other things.
    I've got another slight issue on my 100bhp 51-reg AVB Passat: regardless of whether it's idling or driving along, I can always hear a sound (something between a click and a clunk), although not very loud. It doesn't repeat itself at a high frequency, which makes me thing it might be a belt. It also varies with revs.
    I've tried locating it by listening, but I can't. Could it be a loose belt somewhere, or a timing misalignment, or something else..? I guess I could record the sound, if that would help?
    Secondly, the car's run up about 142k miles now, and it needs a service. Timing kit should be good for a bit longer, so I probably won't be touching that. Other than oil, filters, brake pads & discs, possibly replace the AMM (occasional power dropouts while accelerating) what else should I have checked? I'll probably have a look at the EGR valve as well - I doubt it was ever cleaned..
    Thank you!
  2. Re: Slightly unusual engine noise & servicing
    132 Post(s)
    1980 Post(s)
    Sounds to me like the air temp or recirc flap motor in the A/C has failed.
  3. Re: Slightly unusual engine noise & servicing
    London
    Crasher - quick & to the point, as usual Any ideas as to how I could test that theory? Thanks!
  4. Re: Slightly unusual engine noise & servicing
    132 Post(s)
    1980 Post(s)
    A fault code read of the HVAC system should tell you if my suspicions are correct.
  1. Unusual tapping noise
    By derbydrifter in forum The Commercial Range
    Last Post: 22-11-2012, 06:12 PM
  2. Unusual noise in Golf Mk5 1.4L
    By rainsensor in forum Golf MK5 - 2004 - 2009
    Last Post: 26-01-2009, 12:04 PM
  3. Please Help Unusual gearbox noise!
    By antarmk3 in forum Polo - Derby - Lupo - Fox
    Last Post: 15-01-2009, 11:44 AM
  4. Is my A6 cabin noise unusual?
    By keithtraffic in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 11-08-2008, 02:00 PM
  5. Please Help Unusual ticking noise after fitting new clutch :(
    By AL1210 in forum New Member Introductions
    Last Post: 28-06-2008, 01:32 AM
