Thread: Running problems
Results 1 to 10 of 10
  1. Exclamation Running problems
    Dec 2008
    Hi all im haveing problems with my golf 2.0 8v gti it will run ok then all of a sudden it will start to lose power then starts backfireing when it is doing this the oil light apears on and the rev counter goes mad flicking up and down then snaps out of it and it will run ok again it is so random times it happens last nyt i had an enormous backfire i thought the whole car blew up but then it took of like if nothing happend if any1 can help i wld b so pleasesd
    cheers george
  2. Re: Running problems
    134 Post(s)
    2012 Post(s)
    What year and engine code, 2E, ADY or AGG.
  3. Re: Running problems
    Dec 2008
    its a 96 colour concept not to sure of the code
  4. Re: Running problems
    134 Post(s)
    2012 Post(s)
    AGG. I suspect you have a faulty crank speed sensor or ECU relay. Get a fault code read done first.
  5. Re: Running problems
    Dec 2008
    could you tell me where i could find the sensor and relay i have a spare car so il try swapping them first cheers
  6. Re: Running problems
    Minehad something similar. Turned out to be crank sensor. Its under/behind the oil filter. HArd to fit, you need to support the engine and take the mount off.
    The relay, is in the fuse box, no 167
  7. Re: Running problems
    134 Post(s)
    2012 Post(s)
    The ECU relay is at position 3 on the fuse board, main top row (not to be confused with the clipped on upper relays) third from the left and with the control group number 30 printed on top, part number 165 906 381. Black cased relays are originals and those made in the Philippines or Malaysia are the common problem; the later replacements have a grey case and are made in Germany or Portugal. The Crank speed sensor is on the front of the engine behind the transaxle reaction mount to the cars left of the oil filter but they do not appreciate being swapped around as removing them often leads to failure. If it is in doubt, buy only a genuine VAG dealer supplied part or one made by VDO Siemens and no one else. Hella ones from GSF are a useless.
  8. Re: Running problems
    Dec 2008
    cheers thanks alot il have a look right now
  9. Re: Running problems
    134 Post(s)
    2012 Post(s)
    Quote Originally Posted by admc6 View Post
    167 is at position 12 and is the fuel pump relay, I have only ever replaced a few of these but I keep the ECU relay in stock as I replace about one a month.
  10. Re: Running problems
    yeah sorry, my mistake on the relay number. I did mean to put 30.
  1. A3 running problems
    By ebo in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 20-06-2009, 08:14 PM
  2. running problems '97 adr 1.8 A4
    By doncornholeio in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 29-03-2008, 07:01 PM
  3. Running problems
    By carlyd28 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 09-07-2007, 09:50 AM
  4. running problems
    By njb44 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 05-06-2007, 05:31 PM
  5. running problems
    By bobby b in forum Audi A4 - Archive Topics
    Last Post: 05-01-2007, 09:34 PM
