Thread: squeaking noise
  1. squeaking noise
    Aug 2008
    hi guys i have noticed a squeaking noise coming from the front drivers side wheel(suspension) evrytime i go over bumps in the road.the noise is heard alot better at night with less traffic on the roads and the window down.anybody else experienced this or know what it might be?the car is a 2.0tdi 170 B7 s line.its on a 56 plate and done 37000k.
    many thanks
  2. Re: squeaking noise
    Aug 2007
    Newport, Wales
    7 Post(s)
    In my opinion, the S-Line suspension set-up is about ready for replacement at 40k (in my case, the dampers need replacing).
    Your squeaking could one of many things, but here are two suggestions:
    • Slightly rusty shock absorber piston shaft
    • The flat top coil of the spring is rotating slightly against the upper spring cup (I don't know the proper name for it)
    You could turn the steering to full right lock and spray a load of WD40 at the top and bottom of the spring (where the spring joins other suspension components). If the shock-absorber piston shaft is exposed, give that a squirt and a wipe too.
    It's a quick job, worth a try. Even though the brake disc has a splash guard, make sure you cover the disc with an old towel / newspaper whilst you're spraying the WD40.
    Al.
    [ My Cars: 2011 Caravelle SE TDI LWB | 2015 A1 1.4 TFSI | 2017 Jag F-Type R 5.0 V8 Supercharged ]
    [ Past Audis:
    A6 S-Line 3.0
    V6 TDI Qttr | A4 3.0 TDI Qttr S-Line | S6 4.2 Qttr | A4 2.5 V6 TDI Qttr Sport | A4 1.9 TDI Qttr S-Line | A4 SE 2.0 TFSI Quattro Avant | 2.0 TFSI Roadster ]
    [ Past VWs: Mk1 GTI Cab | Mk3 2.0 Cab |
    Mk3 VR6 | Mk4 R32 | Mk4 V6 MoFo | Mk4 Golf 1.9 TDI| Mk4 Supercharged 2.0 6-speed | VW Touran 2.0 TDI DSG ]
  3. Re: squeaking noise
    Aug 2008
    thanks toff am not gonna mess about with as the car is still under warranty so got it booked in with audi next week see what they come up with.
  4. Re: squeaking noise
    Aug 2007
    Newport, Wales
    7 Post(s)
    I'd give it a quick go.. it may save you a trip to the dealership (or at least eliminate a possible cause), but I take your point.
    Let us know how you get on...
    [ Past Audis:
    A6 S-Line 3.0
  5. Re: squeaking noise
    Aug 2008
    hi thamks toff i have tried that but it still seems to be there,like i said you cant really hear it daytime cos of all the noise etc its at night when roads are quiet,av got it booked in at dealers next week see what they make of it will keep you posted and thanks again.
  1. Squeaking!
    By TDiBoraSam in forum Bora - 1998 - 2005
    Last Post: 28-02-2008, 01:53 PM
  2. Squeaking Noise??
    By take_this_oath in forum Audi A3 - Archive Topics
    Last Post: 21-02-2008, 09:52 AM
  3. Squeaking noise when driving
    By langhurst in forum Eos
    Last Post: 26-02-2007, 06:01 PM
  4. squeaking and ticking
    By rockbadger69 in forum 80 - 90
    Last Post: 17-02-2007, 03:03 PM
  5. Eos squeaking problem
    By langhurst in forum Chat - Completely Off Topic
    Last Post: 10-01-2007, 09:52 PM
