Thread: T5 Cooling fans running continually
  1. T5 Cooling fans running continually
    Mar 2009
    sydney
    Could someone out there tell me the location of the thermo cut out switch on 2005 TDI 2.5 transporter,Im assuming this switch is faulty and causing my problem.
  2. Re: T5 Cooling fans running continually
    The radiator thermo switch is on the side of the radiator, and the fan control unit,is on the left front longitudinal member.I may add that there was a recall on the control units.A fault code read might show up,what is wrong.
  3. Re: T5 Cooling fans running continually
    Mar 2009
    sydney
    thanks Kenny,my problem is the radiator cooling fans are running as soon as the engine is started and remain on until the ignition is turned off.
  1. T5 cooling fans running all the time
    By sunbeam in forum The Commercial Range
    Last Post: 23-03-2009, 11:15 AM
  2. Question Cooling Fans running
    By davidebird in forum Octavia
    Last Post: 20-01-2009, 09:25 AM
  3. A6 cooling fans
    By firefox in forum New Member Introductions
    Last Post: 02-05-2008, 10:43 AM
  4. cooling fans
    By dazzer in forum Golf MK4 - 1999 - 2004
    Last Post: 16-03-2008, 09:11 PM
  5. Cooling fans
    Last Post: 11-03-2008, 08:38 PM
