Thread: Tyre Advice
  1. Tyre Advice
    May 2008
    Southampton
    Hi Guys, so as I was driving up the M3 this morning, I started to hear a weird noise coming from the rear of the car. I pulled over and sure enough the tyre was a bit low. I put some air in and carried on my journey and the noise went away. On the way home however the noise came back, upon closer inspection I could see 3 or 4 big bulges on the inside of the rim! How could this of come about? I havn't over inflated the tyres and I'm pretty sure I've not driven over anything. I was thinking of deflating the tyre and re inflating to see if they went away or would this not do anything? Thanks in advance!
  2. Re: Tyre Advice
    what make is the tyre? is it a dunlop?
  3. Re: Tyre Advice
    Dec 2008
    @classiccarguru1
    Hi Matt,
    You've run the tyre at Too low pressure, the continued flexing of the flat tyre at the bottom of the rim as it rotated (squashed, straightened, squashed, straightened etc) has de-laminated the rubber in the side wall.
    You've knackered the tyre. DO NOT DRIVE ON IT!!!
    Change to the spare and get a new one ASAP.
    It's now highly dangerous as the whole side wall may blow out, and it's illegal. 3 points on your licence.
    Sorry mate, you should check your pressures at least once a month...far cheaper than new tyres or writing off your car with a high speed blow out!
    Regards
    D
  1. Tyre Noise Advice
    By John140 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 16-10-2008, 05:16 PM
  2. A8 Tyre Advice
    By Harry_Boy in forum Wheels and Tyres
    Last Post: 04-10-2008, 07:13 PM
  3. monitoring tyre pressure advice
    By weepiglet in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-02-2008, 02:28 PM
  4. New Tyre Advice - Golf Cabrio Mk 3
    By Treacle in forum Golf MK3 - 1993 - 1999
    Last Post: 20-12-2007, 04:44 PM
  5. Michelin tyre pressure advice (Winter)
    By Marco34 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-11-2007, 12:39 PM
