Thread: A6 Alarm constantly goes off-bone dry footwells
  1. A6 Alarm constantly goes off-bone dry footwells
    Hi my 99 A6 avant alarm just goes off all the time when its locked, I've checked the usual suspects (pollen filter housing, passenger footwell, CCM) and its all bone dry so it doesn't seem to be water ingress.
    I've had the freeware version of vag-com on it which seemed to suggest one of the rear side windows has been smashed (which it hasn't) but not sure if this is correct either.
    Anyone any ideas? does anyone have a wiring diagram for the C5 Avant alarm set up so I can see how the alarm would know that a boot side window is smashed and see if I can bypass it?
    Is it possible to just disconnect the alarm?
    Any info GREATLY appreciated as at the moment I have to disconnect the battery everytime I leave it parked anywhere lol.
  2. Re: A6 Alarm constantly goes off-bone dry footwells
    Mar 2008
    High Wycombe
    Read the fault codes with vag-com and post the text here.
    I didn't think that the Avant had glass break detectors, but if it has, then it might be that one is faulty or has a wiring fault.
    I think the alarm can be disabled with vag-com, but you'd need the registered version.
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  3. Re: A6 Alarm constantly goes off-bone dry footwells
    Jun 2007
    Check the code again. The avant does have a sensor wire in the rear glass so it could just be the connector. Regards Peter
  4. Re: A6 Alarm constantly goes off-bone dry footwells
    ok lads thanks very much for that will have another look
  1. How To Fit A Wish Bone Need Help
    By stephen1989227 in forum Chat - Anything with wheels
    Last Post: 13-03-2009, 05:49 PM
  2. Bora Bone Shaker, Can you help
    By arob in forum Bora - 1998 - 2005
    Last Post: 16-08-2007, 01:46 PM
  3. Mk4 Golf tdi dog bone mount???
    By valley rower in forum Golf MK4 - 1999 - 2004
    Last Post: 20-07-2007, 08:43 PM
  4. A6 with water in footwells
    By grahame78 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 05-02-2007, 02:58 PM
