Thread: intermittent glow plugs warning
  1. intermittent glow plugs warning
    Feb 2009
    Can anyone help with some advice, I have a P reg Sharan TDI & periodicly the glow plugs warning comes mainly if I have been stopped in traffic a while. This does not happen all the time, just intermittently.
    If I turn the car off/on the warning goes which suggests an electrical fault I guess. The car does not suffer in performance when this warning appears (touch wood!!).
    Any ideas / suggestions?
    thanks
    Mark
  2. Re: intermittent glow plugs warning
    Jan 2009
    towcester northants
    check your brake lights when this happens it could be brake light switch
  3. Re: intermittent glow plugs warning
    Feb 2009
    thanks, they do work but it appears you have to press down hard on the brakes to get the lights to come on. not stamp on the hard,but when I gentle used the brakes when parked they did not come on. Also, I had to brake a little sharp the other day and the warning had been on a minute, but went off when I braked... Cheerz for that.
    Where do i find the switch to replace and is this something easy done ? thanks again, much appreciated.
  4. Re: intermittent glow plugs warning
    Jan 2009
    towcester northants
    the switch is located on a bracket in front of your brake pedal it may just need adjustment if they work try this first
  1. Question T4 96 1.9TD - how do you fit glow plugs?
    By tofatnotsoslim in forum The Commercial Range
    Last Post: 15-07-2009, 11:31 PM
  2. Glow Plugs warning Light - Help
    By lindahaughan in forum Leon
    Last Post: 24-03-2009, 11:39 PM
  3. Question Where are the glow plugs? 1.9 TDI T5
    By paul b in forum The Commercial Range
    Last Post: 04-03-2009, 07:35 PM
  4. Question Glow Plugs
    By leafyAudiA4Tdi in forum New Member Introductions
    Last Post: 28-06-2008, 01:32 AM
  5. Please Help Sharan TDI Glow plugs warning light flashes on and off briefly...
    By Smalls in forum Touran - Sharan - Caravelle
    Last Post: 22-05-2008, 07:00 PM
