Thread: Noisy aircon??
  1. Question Noisy aircon??
    Mike McKinstry Guest
    Hi Guys,
    Sorry -quite new to VW problem solving so very glad I have found you!
    When starting car I am getting a noise like a noisey fan/rough /grating almost mechanical noise and have now worked out this noise is only occurring when aircon is run.It does not appear to happen when aircon is off.It has also happened when car has been driving and can be heard over engine noise.
    I am wondering if this is common and whether you think it is the aux belt tension that needs addressing or it could be something to do with the aircon compressor which I believe this belt drives.
    Any ideas-also if it is aux tension how is this done and will the bumper have to come off yet again-already had off for cambelt/a headlight and a rad in 12 months of ownership.
    Oct 2005
    Lutterworth
    The electric fan is often the culprit.
    With the aircon on and I guess the noise present, the electric fan should be running at low speed.
    Use a rag and gently stop the fan and see if the noise stops!
    If the noise is still there it could be the aircon belt tensioner.
    It can be pulled without moving the front into the service position and I have had some success re-lubricating the bearing.
    Failing that it's the compressor itself. £££
    Passat Estate 2002 PD130
    Passat 1.8SE 1998
    Thanks-could be fan as more revs would make noise disappear-I am right in thinking drivers side fan is running with aircon?I suppose i coud try and run fan by bridging terminals-dont know if there will be enough room to get in to plug-this would eliminate belt and comp.If fan is making noise is it bearings and a throw a way job do you think?
    Thanks Mike
    Jun 2006
    UK, Mids
    http://www.bba-reman.com/catalogue/D...ledProduct=112
    "Zexel Aircon Compressor, spring washer holding the swash plate fails. Starts off sounding like a clutch bearing beginning to fail. DO NOT BE FOOLED. Eventually the washer breaks up and will destroy the piston and bores."
    Oct 2005
    Lutterworth
    Quote Originally Posted by Mike McKinstry View Post
    Thanks Mike
    If it's the fan it costs about £60 from GSF.
    The fan power connector runs to the little panel beside the power-steering reservoir. Look for the thick black and red wires.
    It's not hard to stop the fan by friction if it is not at full speed.
    The electric fan runs when the aircon is on, or when the coolant is too hot.
    Passat 1.8SE 1998
    Feb 2006
    Reading, UK
    Sorry to hijack the thread, but I also have a noisey aircon issue. 'tis always squeaking away, worse when aircon is on than off. Looks to me like it is the clutch on the front of the unit that has gone. The aircon has been disconnected since I got the car, but I put the belt back on a month ago to test it and it still blew cold. Do you think that a) 'tis the clutch, and b) the clutch is replaceable without having to de-gas the system? It's not worth a new compressor on the car (new compressor £500, car only cost me thrice that)..
    If the OP's problem isn't the fan - it might be a similar problem to mine..
    B5 2000 1.8T Sport Estate
    178,000 miles and counting..
  1. Noisy aircon
    By swgf in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 21-07-2009, 10:47 PM
  2. Aircon
    By OrangeMikey in forum 80 - 90
    Last Post: 19-05-2007, 05:35 PM
  3. Noise from aircon
    By blakey in forum Audi A4 - Archive Topics
    Last Post: 16-04-2007, 03:55 PM
  4. Aircon issue
    By nickynibbles in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 15-04-2007, 03:24 PM
  5. do i have aircon????
    By dannygr27 in forum Touran - Sharan - Caravelle
    Last Post: 27-10-2006, 08:54 PM
