Thread: Airbag Light
  1. Airbag Light
    My airbag light on my 98 a4 2.5tdi quattro is on. The fault code I have is
    01222 Crash Sensor Airbag passenger side G180
    44-00 short circuit.
    I have disconnected the wires under the passenger seat (red plug one wire and yellow plug 2 wires. The terminals were clean. I reconnected them and used a cable tie to prevent any movement of the connectors. Tried a reset and the airbag light is still shown same.
    I would appreciate some advice on this.
    thanks
  2. Re: Airbag Light
    Crash sensor, passenger's side airbag (lateral acceleration sensor) -G180 short circuit
    Short in wiring to positive or earth.
    Crash sensor defective.
    Control unit for airbag -J234 defective.
    Fault finding according to current flow diagram
    Current Flow Diagrams, Electrical Fault-finding and Fitting Locations binder
    Replace crash sensor -G180.
    Replace control unit for airbag -J234.
  3. Smile Re: Airbag Light
    Good News
    I removed the seat ns and lifted the carpet. The ns off the car had water ingress.
    The shock sensor mounting bolts and connections were all rusty. I dried the car out and cleaned up the bolts and terminals.
    Used Vagcom to reset the ecu.
    The air bag light has now cleared. I have left the carpet out whilst I identify were the water came from. I removed the nsf and nsr door seals and re sealed them , applied a pressure washer around the doors and as now it appears watertight.
    Thanks for your help.
    98 A4 2.5Tdi Quattro Avant (current)
    90 Coupe 2.3E (sold)
    90 A80 1.8E (sold)
    88 A100 CD 2.2E (sold)
    83 Coupe GL5S (sold)
  4. Re: Airbag Light
    May 2007
    sounds like the drain holes in the plenum chamber are blocked.
    remove battery, and clear them. ( also often one under brake servo)
  5. Re: Airbag Light
    Ill try that, thanks for the advice.
    90 A80 1.8E (sold)
  1. Airbag Light
    By Imizz in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 25-02-2009, 08:12 PM
  2. Question Airbag light - on and off
    By egTT in forum Audi A3 - Archive Topics
    Last Post: 14-10-2008, 09:01 PM
  3. Please Help Airbag light
    By Big John in forum Golf Plus
    Last Post: 01-09-2008, 07:42 PM
  4. a4 airbag light
    By fatfighter in forum Audi A4 - Archive Topics
    Last Post: 10-11-2007, 11:15 PM
  5. Airbag Light!!!!!!
    By diamond1 in forum Polo - Derby - Lupo - Fox
    Last Post: 03-04-2007, 06:18 PM
