Thread: How does your A4 drive - vibration through accelerator pedal
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. How does your A4 drive - vibration through accelerator pedal
    Nov 2008
    Hi all
    I've noticed a droning vibration through my accelerator pedal when cruising at speed i.e. 40 up to national. Its more noticeable when I feather the accelerator lightly during motorway driving.
    Its like a tiny be constant droning vibration which is very annoying. It seemed to start when I took my car into the dealer and they 'updated the engine software'.
    I also noticed vibration through the car at idle i.e. when sitting in the car in the morning I feel vibration through my back side sometimes lol
    The car drives slightly different in first gear which is probably expected with such an upgrade - its less harsh when accelerating in 1st gear but more restrictive (if you know what I mean)
    I have it book in at Audi again but would like to go with some further information or see if anyone has had a similar issue. I know a few have had issues with the engine/gear box mounts so thinking this could be a possibility??? or it could simply be the engine reacting badly to the software upgrade???
    General question to all - how does your Audi drive? Do you feel any vibration at all through the acceleration pedal or anywhere else in the car when driving? - cheers!
  2. Re: How does your A4 drive - vibration through accelerator pedal
    May 2008
    I get a kind of vibration/lumpy feel through the pedal and the steering wheel but it happens at any speed.Also if i keep the clutch pedal in i,m sure i get some feedback,lumpiness then also.Have not taken it back to audi for a check though as i'm sure it would be charactaristic of the car.One more thing,when i reverse on full lock i get a high pitched squeal,took it to the garage for this and the buggar didnt do it on that occasion.
  3. Re: How does your A4 drive - vibration through accelerator pedal
    Nov 2008
    Cheers stumpy
    Anyone else?.... More feedback will be greatly welcomed
  4. Re: How does your A4 drive - vibration through accelerator pedal
    Aug 2007
    Newport, Wales
    7 Post(s)
    I notice you don't mention the clutch anywhere in your post... do you have a manual or an auto mate? (I presume it's a manual).
    Perhaps a daft suggestion: you haven't had your CAT / mid-section exhaust replaced recently have you? Sometimes a badly positioned exhaust pipes can cause vibrations (although mainly through the gear stick as opposed to the pedals).
    How many miles has your car done? Is it possible your clutch is on it's way out?
    Lastly, what's your engine please?
    Al.
    [ My Cars: 2011 Caravelle SE TDI LWB | 2015 A1 1.4 TFSI | 2017 Jag F-Type R 5.0 V8 Supercharged ]
    [ Past Audis:
    A6 S-Line 3.0
    V6 TDI Qttr | A4 3.0 TDI Qttr S-Line | S6 4.2 Qttr | A4 2.5 V6 TDI Qttr Sport | A4 1.9 TDI Qttr S-Line | A4 SE 2.0 TFSI Quattro Avant | 2.0 TFSI Roadster ]
    [ Past VWs: Mk1 GTI Cab | Mk3 2.0 Cab |
    Mk3 VR6 | Mk4 R32 | Mk4 V6 MoFo | Mk4 Golf 1.9 TDI| Mk4 Supercharged 2.0 6-speed | VW Touran 2.0 TDI DSG ]
  5. Re: How does your A4 drive - vibration through accelerator pedal
    Nov 2008
    Its a 2.0 tdi, done under 40k, manual
    Had clutch replaced which made the clutch so much smoother but still getting vibration through gas pedal. I'm not sure whether its just general cabin vibration now as I sat in the passenger side and could feel the vibration through the floor
    Dunno whether its just me with a hugely sensitive foot lol
  6. Re: How does your A4 drive - vibration through accelerator pedal
    Nov 2008
    oh and I havent had anything done to the exhaust or CAT
    ta
  7. Re: How does your A4 drive - vibration through accelerator pedal
    May 2007
    Leeds Currently (Untill work change their minds again...)
    Quote Originally Posted by Gee_Hee View Post
    Howdy. My b7 (2005 19tdi se saloon) shudders and vibrates when idling and at around 2000rpm. its the flywheel. that can become 'unbalanced' casuing the shuddering/vibration. Its really noticeable on my motor but after some local warranty screwing with the dealer ( not audi but has block exemption for servicing) getting it sorted next week. Bit annoying as the car has only 70000 miles but its very common apparantly as most new cars have these dual mass or floating flywheels. getting mine replaced with a solid wheel so hopefully no more problems.
    Hope this helps.
  8. Re: How does your A4 drive - vibration through accelerator pedal
    Quote Originally Posted by Mafu View Post
    Hope this helps.
    The purpose of the dual mass flywheel, mostly fitted to Diesels are to reduce vibrations caused by the long stroke characteristics of the engine, a solid flywheel will increase vibrations, not reduce them.
  9. Re: How does your A4 drive - vibration through accelerator pedal
    May 2007
    Quote Originally Posted by B8 TDI View Post
    Its the dual mass wheel causing the problems - its become unbalanced the solid wheel is much less likely to become unbalanced.
  10. Re: How does your A4 drive - vibration through accelerator pedal
    Nov 2008
    anyone else?
  1. Please Help Stiff Accelerator pedal
    By westy123 in forum Golf MK2 - 1984 - 1992
    Last Post: 03-01-2009, 08:09 PM
  2. Accelerator Pedal
    By nicky900 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-12-2008, 09:03 PM
  3. Accelerator Pedal
    By JoGibson in forum Golf MK4 - 1999 - 2004
    Last Post: 19-10-2008, 03:16 PM
  4. Please Help Accelerator pedal
    By firestarter in forum 80 - 90
    Last Post: 27-09-2008, 11:04 PM
  5. Accelerator pedal
    By Cossie 2.5 in forum Golf MK4 - 1999 - 2004
    Last Post: 22-07-2007, 12:32 PM
