Thread: 1.9 tdi and veg oil
  1. 1.9 tdi and veg oil
    mystic.bertie Guest
    i am collecting my '01 A6 1.9tdi on sunday, im wondering if it will be possible to run it with a little veg oil ie 10%
    i have been running my last 2 cars on filtered waste veg oil but im getting fed up filtering so much of the stuff so im going back to an economical diesel
    im just assuming there wont be any harm using a little filtered waste veg oil will there, i have no intention of using a high mix of wvo
  2. Re: 1.9 tdi and veg oil
    Jul 2007
    Cheshire, or my A6
    Quote Originally Posted by mystic.bertie View Post
    I suppose you could do it if you have the 1.9 TDI 110 not the 130 but I still wouldn't recommend it at all. Too many potential fuel supply problems for my liking.
  3. Re: 1.9 tdi and veg oil
    mystic.bertie Guest
    Quote Originally Posted by paul b View Post
    its the 115bhp version, is this just the last one of the 110bhp models and what is the engine code so i can look into this further.
  4. Re: 1.9 tdi and veg oil
    Jul 2007
    Cheshire, or my A6
    The engine code will begin with A and is three letters long. Can be found on the ID label in the spare wheel well or in the front of the service book, or on the timing belt cover.
  5. Re: 1.9 tdi and veg oil
    MikkiJayne Guest
    The AFN is the last 4-cyl TDI engine which Audi say can run on biodiesel. Note thats proper biodiesel, NOT waste veg oil.
    More thoughts and opinions here: https://www.vwaudiforum.co.uk/forum/s...ad.php?t=60767
  6. Re: 1.9 tdi and veg oil
    Dec 2008
    Ely, Cambs
    A mate of mine has a golf 4 gt tdi 1999. He's been using up to 30% mix with derv direct into tank during summer months. If using in winter you will need to heat it up. For info on what this may require google elsbett it's a german company specialising in veg oil conversions. Would not recommend using used oil unless really well filtered and any water residue removed by boiling first.
  7. Re: 1.9 tdi and veg oil
    May 2007
    as long as you don't mind changing a few filters, the pump etc. then you will be fine !
    High pressure diesels and veg oil don't mix.
    stick to regular fuel or genuine biofuel
