Thread: 2.8Q cambelt change
Results 1 to 8 of 8
  1. 2.8Q cambelt change
    Feb 2009
    hampshire
    Sorry if this is a repeat question but when the cambelt is changed does it come as kit? ie cambelt waterpump and tesioner? been quoted 350 all in for the job. is this reasonable? i understand the front end has to come off.
    thanks
    clive.
  2. Re: 2.8Q cambelt change
    Jan 2009
    towcester northants
    cambelt kit comes with belt and idlers only
    water pump is seperate
    £350 sounds ok ish dealers are charging £540 for 1.9 tdi cambelt and water pumps
    the front of car needs to come off to gain access/to give room so you can get to bolts etc
  3. Re: 2.8Q cambelt change
    Mar 2007
    11 Post(s)
    if its £350.00 all in thats very good you can get your own water pump for about £30.00 have it done at the same time i paid £570.00 for a timing belt tensioners and water pump fitted on a 2.8 a6 2 years ago so yes that is a bargain just as long as its a compitant garage
  4. Re: 2.8Q cambelt change
    Feb 2009
    hampshire
    Thanks for your help. car was owned by lady from new and has 11 maindealer stamps and 2 indies. Am being a fussy bugger and getting it changed as i always would when buying any car....It saves a lot of effing and shouting later on. here she is. not bad for a first car. sounds sad but very proud of it as i saved hard for it
  5. Re: 2.8Q cambelt change
    london/ UK
    Depending on the year, there are 2 cambelt kits. 1 cost 140 quid the other 240 quid. Add a thermostat, a water pump, 2 drivebelts and 5L of coolant and its too cheap as the job takes 4.5 hours ! I have done one to a forum member and i did not break even as i have quoted him £350 fitted ! I had to buy the later expensive full cambelt kit (wich contains the belt, 2 idlers, a tensioner and the hydraulic damper), the thermostat, the water pump and the belts wich costed £311 inclusive of VAT. If they just replace the belt without replacing the idlers then walk away chances are that the belt will fair writing off the car ! Make shure they fit a new water pump and thermostat as if they fail, its a belt off job...You can get in touch with me if you want a well done job cheaper...
  6. Re: 2.8Q cambelt change
    Feb 2009
    hampshire
    Its a 99 T-reg. just want some1 trustworthy that wont take the **** out of me. However i do believe in paying a good price for a good job well done. Do you mind me asking how many you have done?
  7. Re: 2.8Q cambelt change
    Mar 2009
    I also have a 1999 T-reg 2.8 that's due a cam belt change (82K).
    Clive, how did you get on with yours? Any tips?
    Adamss24, I'd PM you for a quote and more details but I'm a newbie on this forum so can't until a post 5 comments ... perhaps you could email me?
    Andrew
  8. Re: 2.8Q cambelt change
    london/ UK
    Quote Originally Posted by clive30v View Post
    I would say over 100 cambelts on various engines/makes... Some peoples here on forum had their cambelts replaced by me and no issues yet + i do know what i am doing ! You could email me at adamss 24@poczta.fm for more details or call me on 077 899 12128. Cheers.
    Chris.
  1. 1.6 SE Cambelt change
    By Tenfoot in forum Bora - 1998 - 2005
    Last Post: 03-11-2008, 02:41 PM
  2. Cambelt change and auto gearbox oil change
    By shabazmo in forum Golf MK4 - 1999 - 2004
    Last Post: 26-10-2008, 11:53 AM
  3. cambelt change
    By sean71 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-10-2008, 03:12 PM
  4. TDI cambelt change
    By john493 in forum Golf MK4 - 1999 - 2004
    Last Post: 11-06-2008, 09:47 PM
  5. cambelt change on tdi
    By HOVISVW in forum Chat - Completely Off Topic
    Last Post: 14-10-2006, 11:23 AM
