Thread: 02 PASSAT 130 TDi ESP Wng light+ Judder
  1. 02 PASSAT 130 TDi ESP Wng light+ Judder
    Feb 2009
    Hello,
    I have an 02 plate Passat TDi 130pd Saloon with a virtually trouble free 145,000 on the clock.
    A fault has recently developed... when I apply moderate to heavy acceleration, power is not applied smoothly and the car "judders". Occassionally, but not everytime, the ESP warning light is illuminated and any acceleration thereafter is impossible until the ignition is switched off/on, which temporarily cures the problem.
    The frequency of this problem occurring seems to be increasing.
    Having read through this forum, I guess I will need a diagnostic check to pinpoint the problem, but the purpose of posting is to enquire if this is a common problem and ask if anybody knows the likely cause?
    Can anybody give me some guidance please?
    Thank you.
  2. Re: 02 PASSAT 130 TDi ESP Wng light+ Judder
    134 Post(s)
    2018 Post(s)
    You need a fault code read first, there are various different things it could be.
  3. Re: 02 PASSAT 130 TDi ESP Wng light+ Judder
    STIRLING
    remove the intake section with the stop flap it also has a pipe from bottom of it to exhaust manifold.remove this which will more than likely be thick with wet oily carbon.get it all shinning and re-fit and check 9/10 sorted.
  4. Re: 02 PASSAT 130 TDi ESP Wng light+ Judder
    Feb 2009
    Thank you very much for your advice swany99.
    I will do as you suggest... fingers crossed!
    If it doesn't work, no worries, I'll do as Crasher suggests and get a fault code read.
  5. Re: 02 PASSAT 130 TDi ESP Wng light+ Judder
    Chester-le-Street, United Kingdom
    does the asr light come on also?
    was thinking of tyres?
    crasher is your best bet,
    regards,
    stewy.
    first time i was up a ladder i was down a well
    4th cog,--two to go
  6. Re: 02 PASSAT 130 TDi ESP Wng light+ Judder
    Feb 2009
    Hello STEWY L,
    Thanks for taking the time to reply.
    The asr light does not illuminate, only the esp.
    The tyres are Pirelli P6000 all round, the two front ones are brand new having been replaced only 200 miles ago.
  1. Please Help car judder and esp light comes on
    By swany99 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-01-2009, 06:56 PM
  2. passat 1.8 2ov s clutch judder
    By lone wolf in forum Chat - Anything with wheels
    Last Post: 25-04-2008, 06:21 PM
  3. VW Passat 2.0DTI 170 DSG Judder
    By thomas owen in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 28-03-2008, 07:16 PM
  4. engine judder / vibrations and esp light stays on
    By gusyah in forum Archive posts
    Last Post: 29-01-2008, 02:49 PM
  5. Help! Loss of power, ESP Light on and Engine Judder
    By Jase1000 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-01-2008, 08:32 AM
