Thread: Audi A3 Water Temperature
  1. Audi A3 Water Temperature
    Feb 2009
    Southampton - United Kingdom
    I appreciate that this might be little more than paranoia on my part but I've just observed something odd with the water temperature on my A3 ('99 1.8T factory standard!) that I've never seen before in a year of ownership...
    I was nearing the end of a brief journey from home to work and back (i'd say less than 20 miles round-trip, half-hour total journey time; mainly motorway) whereby I became practically obssessed by the behavior of my water temperature gauge: In the last few miles of my journey, just as I was leaving the motorway I saw the temperature needle drop to below 85°C; it's normally between 85°C & 90°C. As I made my way through a couple of 40mph roads the temperature began dropping further still where it bottomed out at about 79°C - I have never seen it drop that low at the tail end of a good run! The outside temperature was +9°C so it wasn't exactly freezing either.
    When I finally pulled up outside my flat I just sat at idle for a bit and watched as the temperature gauge made its slow crawl back up to 90°C.
    I seldom hear the fan kick in (it's pretty quiet!) so I'm afraid I can't tell you if that was stuck on or not. The moment I arrived back at the flat I got out and put my ear to the grill; the fan definitely wasn't stuck on at that point!
    Can anyone please tell me: Have I just witnessed an early warning sign to something that may grow into a complete ballache? Would the in-car computer warn me of anything potentially catastrophic??
    Last year I had serious cooling issues with a Peugeot 306 D-Turbo which ultimately resulted in a trashed engine in a shell of a car which ultimately I had to sell for a miserable £50! (hence the paranoia!)
    Thanks in advance for any advice you can offer!
  2. Re: Audi A3 Water Temperature
    Jan 2009
    there are (2) separate sets of components involved:
    (A) cooling system "thermostat" and "water pump"
    thermostat may by sticking / not moving freely / suddenly opening/closing
    change thermostat immediately - this must be eliminated to troubleshoot "others" - ENGINE MUST BE STONE COLD - change o-ring as well
    water pump has resin impellar which gradually crumbles with age - driven by timing belt - always replace water pump when replacing timing belt - there is german water pump with iron impellar - prefered replacement
    (B) "control module" of electric fan(s) and "temperature sensor" (lower left side of radiator, on inside/engine bay side) of electric fan(s)
    the fan control module is a known issue with older A3 1.8T's - this should always be changed together with fan temperature sensor - this gradual drifting of sensor combined with light welding/burning of control module contacts will result in irregular fan operation and prolonged fan operation - but not necessarily continuous fan operation at beginning of failure period
    I assume NO coolant leaks and normal coolant appearance in reservior sphere (pinkish/redish/purplish smooth liquid - NO solid material)
    Begin with engine water thermostat now
    (1) additional item - look at back end of cylinder head near air filter box & battery box - looking down you will see hose(s) from radiator to cylinder head - there will be (1) or (2) electrical connectors to water temp sensors - if you still have "black" top sensor (4-pin) and not "GREEN" top sensor - immediately change to "GREEN" top sensor - requires green sensor/o-ring/resin "c" clip - ONLY WHEN ENGINE IS STONE COLD - DO NOT open reservior - only small amount of coolant will leak out - be certain to lift out old o-ring
    I need to add that a water temp guage w/pointer abnormal movements occasionally (but not always) indicates a corrupted dash instrument cluster control chip) - keep in mind for future
    start w/ thermostat (do not fit lower opening temp aftermarket / fuel mileage will really suffer) and confirm "GREEN" top sensor cold start/combi w/guage sensor is fitted already - if not immediately fit
    after doing these (2) things, you can determine condition of fan control module...
  3. Re: Audi A3 Water Temperature
    Feb 2009
    Ed,
    Thanks for taking the time to compile this; at least I have a direction to go now!
    If something arises from this I'll post it here!
    Second of all, he knows everything. He knows what you think. He knows what you thought, He knows what you think you thought, what you think you're gonna think... He knows that you thought you were gonna think of that!
    - George Carlin.
  4. Re: Audi A3 Water Temperature
    Jan 2009
    Stoke-on-Trent
    Sounds like the waterpump to me, very much doubt it will be thermostat.
    Remove and check waterpump
    Dave
    Servicing, Repairs, Diagnostics and Re-mapping in Staffordshire
  5. Re: Audi A3 Water Temperature
    Jan 2009
    given a 10yr old 1.8T engine, it is now time to change original thermostat, very likely no longer opening at correct temp - usually drifts to lower opening temp delaying eng warm-up
    this is practical & inexpensive routine maintainance
    this also ensures that the water pump impellar failure/resin-breaking-apart can be accurately diagnosed - important because this is significant engine repair cost issue - at 10 yrs this will mean timing belt, tensioner pully, pully bolt, hydraulics AND water pump / o-ring and if necessay crankshaft front oil seal & crank belt sprocket & keyway & sprocket bolt
    the water pump is not rebuildable and should be replaced with alternative recognized german iron impellar replacement water pump
    remember that water pump shaft serves as pivot for timing belt and is critical timing belt component - NO china pumps!
    and at 10yrs thermostat replacement is an accepted practice
  1. Question 1999 A4 Oil and Water Temperature
    By robjames80 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-03-2009, 11:49 AM
  2. Please Help Water temperature
    By smilin-s in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-07-2008, 01:34 PM
  3. 2.4 V6 AGA engine water / oil temperature
    By lonky in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 04-03-2008, 04:08 PM
  4. Water Temperature Indicator
    By padrag_king in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 22-07-2007, 05:27 AM
  5. WATER TEMPERATURE SENDER
    By taff in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 30-11-2006, 06:30 PM
