Thread: Diagnosing faulty Missing/Knocking sound
  1. Diagnosing faulty Missing/Knocking sound
    Mar 2008
    Is there any way of using vagcom to try and diagnose my problem with my golf m4 2003 tdi 150 which has a missing and knocking sound on the engine. My friend has the vagcom software but not sure if he knows how to fully use it. My problem maybe a faulty injector or wiring loom on the vagcom it didnt give any error codes. Is there any tests we can do using the vagcom to try to diagnose or rule out certain things?
    Any tips/help appreciated.
  2. Re: Diagnosing faulty Missing/Knocking sound
    london/ UK
    I would say worn camshafts lobes...muchos dineros !
  3. Re: Diagnosing faulty Missing/Knocking sound
    135 Post(s)
    2026 Post(s)
    VAG-COM doesn’t diagnose as such, it reads fault codes stored by the car and relay info from the electronic control units. The knocking noise on yours will be the camshaft and lifters have failed and will cost you around £1500 to have fixed properly, be very wary if anyone quotes less. The cam lobes can show up on VAG-COM as injector imbalances but you really need to know what you are doing to use that display section.
  1. Scirocco's sound system - the missing info?
    By Hogwarty in forum Scirocco - 2008-
    Last Post: 13-02-2009, 01:14 PM
  2. 02 polo knocking sound at front
    By n.howard in forum Polo - Derby - Lupo - Fox
    Last Post: 12-01-2009, 10:08 PM
  3. KNOCKING SOUND GOLF SDi 2001
    By bigbrian123 in forum Golf MK4 - 1999 - 2004
    Last Post: 02-01-2009, 01:31 PM
  4. Knocking sound when driving
    By k9max in forum Golf MK5 - 2004 - 2009
    Last Post: 14-10-2007, 09:40 AM
  5. Knocking sound from back
    By tony_anon in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-04-2007, 09:39 AM
