Thread: polo 1.4 1999 fuel injector problem???
  1. polo 1.4 1999 fuel injector problem???
    Feb 2009
    Hi i have a polo 1.4 1999. It is running as if on three cylinders, however the plugs and leads, cap coil etc all appear to be good. I disconnected the injectors one by one and number 4 resulted in no change to the engines performance?? How do you remove the injector from the rail?? surely it doesnt come as part of the rail and you need to buy 4 injectors and a rail?? my initial fault was high idle could this have been the management system attempting to compensate?? Thanks for any help, this is urgent as someone wants to buy the car!!! Cheers
  2. Re: polo 1.4 1999 fuel injector problem???
    Jan 2009
    towcester northants
    dont usually have injector problems
    the rail unbolts from the inlet and injector unclips from rail
    i would check the inlet manifold gasket first also the servo pipe
  1. Fuel Injector failed Urgent advice needed please!!
    By Grandmaster80 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 08-02-2009, 01:15 PM
  2. Please Help 1999 Polo 1.4cl engine problem
    By 5ilv3rfox in forum Polo - Derby - Lupo - Fox
    Last Post: 06-02-2009, 08:47 AM
  3. Please Help Fuel Injector
    By haroon_19 in forum Golf MK4 - 1999 - 2004
    Last Post: 02-12-2008, 09:25 PM
  4. Question Fuel pump injector problem
    By dan_r in forum Audi A3 - Archive Topics
    Last Post: 06-10-2008, 11:24 AM
  5. Fuel Filter + injector cleaner
    By arl_gti in forum Golf MK4 - 1999 - 2004
    Last Post: 24-04-2008, 05:49 PM
