Thread: VAG commander
  1. VAG commander
    Feb 2009
    Hello:
    Do any of you use VAG commander from abritus72 ?? Is it better that VAG-COM ??
  2. Re: VAG commander
    Nov 2008
    folkestone.kent
    i dont use it so i carnt comment on it,but i do use vcds and the backup and support you can get from the forum is second to none and from ross tech so i would very much lean towards vcds,if you want to do immobilisers then vag commander probably goes that bit further but no dout some members do use it .....but vcds all the way for me...
  3. Smile Re: VAG commander
    Feb 2009
    Thanks very much
  4. Re: VAG commander
    Nov 2008
    folkestone.kent
    no problem and good luck with your choice
  1. VAG K + CAN Commander Software version 5.3
    By brownr3 in forum VCDS - General Questions
    Last Post: 15-09-2008, 06:55 PM
