Thread: R32 conversion
  1. Question R32 conversion
    Feb 2009
    Hello, I'm a new member and I need some help. I'm doing a mk2 R32 conversion and I'm having some difficulties fitting the radiator. At the moment I've got a corrado vr6 radiator but I can't fit the front panel without cutting a bit off where the inlet pipe of the radiator is. Basically there is not much room between the engine ( inlet manifold) and the front panel. Has anyone out there dealt with this problem or can anyone offer any advice or point me in the right direction. Thanks.
  2. Re: R32 conversion
    Feb 2009
    if you need help fitting an R32/36 into a mk2 chassis get in touch with andy @ storm developments. they specialise in these conversion and should be able to help you out.
  3. Re: R32 conversion
    Feb 2009
    Quote Originally Posted by luminosa View Post
    Thanks for replying. I'd like to contact Andy, do you happen to have his complete e-mail address or telephone number. Thanks again. George.
  4. Re: R32 conversion
    Feb 2009
    http://www.stormdevelopments.co.uk/
    check out this website or give them a call on (0) 118 9810963
    its probably better to call them up as they're always busy,
    hope this helps.
  1. vr6 conversion
    By xxx220 in forum The Commercial Range
    Last Post: 10-03-2008, 01:49 AM
  2. a4 LPG conversion ?????
    By 00carberry00 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-03-2008, 10:00 PM
  3. 2.7t LPG Conversion
    By Joust in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 18-12-2007, 09:40 AM
  4. HID conversion
    By V5_170Mk4driver in forum Golf MK4 - 1999 - 2004
    Last Post: 19-09-2007, 11:03 AM
  5. mk3 1.8t conversion
    By swissgolf in forum Golf MK3 - 1993 - 1999
    Last Post: 04-06-2007, 08:52 PM
