Thread: Cant get connection
Results 1 to 10 of 18
  1. Cant get connection
    Sep 2007
    Liverpool
    I have installed 409.1 freeware, I have a third party USB interface, when I run the options to set the interface, my laptop finds the interface com3
    says
    port status: ok
    interface: found
    Type: serial pass-through
    Opto/Iso: No
    Ross-Tech Design: No
    I cannot get it to connect to my Passat (2003) (B5)
    any help would be appreciated
    Dont want to pay for registration if I cannot get it working.
  2. Re: Cant get connection
    Aug 2008
    hi where did you get this cable from you might need to find a softwear driver for it if you can find one.
    better off getting a cable from ross tech
    paul
  3. Re: Cant get connection
    Canada
    have you got the ignition on?
  4. Re: Cant get connection
    Sep 2007
    Liverpool
    Quote Originally Posted by saabsalltheway! View Post
    paul
    Any idea what the cost of the cable is??
  5. Re: Cant get connection
    Sep 2007
    Liverpool
    Quote Originally Posted by onzarob View Post
    Yes ignition is on.
  6. Re: Cant get connection
    Aug 2008
    i did that the other day only realised after second attempt to connect
  7. Re: Cant get connection
    Canada
    It happens, a geniene cable will cost approx £250 is you look on the ross tech website http://www.ross-tech.com there are authorized suppliers. www.gendan.co.uk and www.ilexia.co.uk.
    I have a 3rd party cable and it worked fine with a 1999 A4. Not sue why yours doen't i don't think the 2005 passat is CAN ?
  8. Re: Cant get connection
    Aug 2008
    Quote Originally Posted by PETER G View Post
    i think about £225 fully registered latest version and with after sales back up or use yor cable and buy a licence for $99.
    did you have to install a driver when you brought the cable get in touch with them who you brought cable from.
  9. Re: Cant get connection
    Canada
    says
    port status: ok
    interface: found
    Opto/Iso: No
    Reading this again the problem isnt the cable driver its, going to be at the car end. try it on another car and see if it the same
  10. Re: Cant get connection
    Sep 2007
    Liverpool
    How the plot thickens, I have had my car connected to VAGCOM version 311 with my old lap top using a 3 rd party interface with a serial connection. The big problem being my new lap top does not have a serial port...
  1. I-pod Connection
    By Martin S in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 26-11-2012, 10:03 PM
  2. I Pod connection
    By BSM Victor in forum In Car Entertainment
    Last Post: 14-01-2009, 03:26 PM
  3. vag com connection
    By passing in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 31-10-2008, 11:16 PM
  4. MP3 connection?
    By A6_JAck in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 30-08-2007, 05:41 PM
  5. MP3 Connection
    By judian2462 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-06-2007, 06:44 PM
