Thread: Disable Air Bag Light
Results 1 to 10 of 20
  1. Re: Disable Air Bag Light
    Apr 2007
    You could do with reading the fault code with vag-com to be sure which airbag it is and the exact fault. I cut the under seat connectors off and soldered the wires together, this cleared the first fault. But I also had an 65535 airbag control unit fault which vag-com cannot clear, but I got another tool to clear that and now its ok.
    If you don't have vag-com it might be worth posting in the vag section to see if anyone local can read the faults for you.
    Frenchman
  2. Re: Disable Air Bag Light
    Nov 2008
    Hi i will try that later, i too have chopped off the connector and soldered it up with out any luck. Thanks for your advice cheers
  3. Re: Disable Air Bag Light
    Norfolk
    It is possible to use a substitute resistance to isolate which air bag circuit is faulty. You need a vag-com read to point you towards a circuit so you don't have to test them all. Unless you are comfortable with electronics i would leave this to a specialist.
  4. Re: Disable Air Bag Light
    Nov 2008
    Hi Martin so although i know its my n/s side airbag thats causing the problem, you don't think i can just adjust the resistance in the wiring of the side airbag circuit ie introduce resistors into the circuit problem is where and how!!! Oh well i will have to acquire vag-com read from someone with knowledge of how to go about this mod preferably in my area Bristol.
  5. Re: Disable Air Bag Light
    Norfolk
    I am not suggesting you do this. MESSING WITH AIR BAGS CAN BE DANGEROUS AND EXPENSIVE.
    If the wires were cut where the seat connector was. If a variable resistor was placed across the cut ecu wires. (NOT AIR BAG) Starting with the variable resistor set at more than 5 ohms.
    The varaiable resistor could be wound down abit at a time. Each time it was wound down the light woud have to be reset. At about two ohms, the light should go out and stay out.
    If it does you know the seat wire or seat airbag is faulty. A resistance MUST NOT be left substituted for the passenger airbag !!!!! NEVER try to measure the resistance of the airbag circuit.
  6. Re: Disable Air Bag Light
    Jul 2008
    In the bad old days people would wire the airbag light to the oil light so as to pass an MOT.
  7. Re: Disable Air Bag Light
    Nov 2008
    Hi thanks for your input most helpful, i realise this could be dangerous without some skill. The resistor you mention would only have two legs and i know there is three wires under my seat so i'm not really sure which wires would be used to accomadate the resistor? I might well try this approach but only with correct info on those wires or am i barking up the wrong tree?????
  8. Re: Disable Air Bag Light
    Norfolk
    I'm away at the moment so can't get to the info. You only bridge two wires but I can't remember which colours. If I can I will get back to you with the colours.
  1. Possible to disable immobilizer
    By jb1978 in forum VCDS - General Questions
    Last Post: 14-10-2015, 09:16 PM
  2. Question EGR disable
    By del649 in forum 80 - 90
    Last Post: 31-07-2008, 10:11 PM
  3. Disable EGR
    By rickworldtravel in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-06-2008, 06:28 AM
  4. How To Disable Dim Dip
    By noppygolf in forum Golf MK3 - 1993 - 1999
    Last Post: 13-09-2007, 12:43 PM
  5. Does anyone know how to disable TV in Motion?
    By Robsey in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 31-05-2007, 08:56 AM
