Thread: rock hard brake pedal
  1. rock hard brake pedal
    Feb 2009
    hi i'm new to all this but can anyone help me i have an A4 1.9tdi (2002) my brake pedal has just gone rock hard. a friend said something about vacuum pump failure or check the plenum valve. i have no idea where these are located.
  2. Re: rock hard brake pedal
    Mar 2007
    Lancashire
    Quote Originally Posted by bobby1966 View Post
    sounds like the vaccum assistance is not working. Worth checking the plenum chamber. It is easlily removable. The strip of plastic where the battery cover is - all this comes off. Undo the rubber engine compartment seal strip and then pull the plenum cover towards you away from the windscreen. This will reveal the battery, servo, brake fluid reservoir etc. check there is no water settling there. It's quite common on these cars. Failing that, I'm not too sure as I've never delved into the vacumm assistance.
    A4 1.9TDI 160bhp Sport - 2001 (51)
    Re-map by more-bhp.
    TT 3.2 V6 DSG quattro 270BHP - 2003 (53)
  3. Re: rock hard brake pedal
    131 Post(s)
    1979 Post(s)
    Could be the vacuum pump or the supply pipe or even a water damaged servo.
  4. Thumbs up Re: rock hard brake pedal
    Feb 2009
    Quote Originally Posted by Marco34 View Post
    hi thanks for that i have checked the plenum chamber and it was full of water so i removed debris and all the water flushed away out of the bottom. the brakes are better but they are still quite hard, is it possible for the water to get into the pump itself ?
  5. Re: rock hard brake pedal
    Mar 2008
    Just Cumbria now.
    Yes, it rusts the internals. See here, A4s, A6s, and Passats, of a similar age are all affected.
    Nothing to see here, move along..
  6. Thumbs up Re: rock hard brake pedal
    Feb 2009
    hi where is the pump or supply pipe located
  7. Re: rock hard brake pedal
    131 Post(s)
    1979 Post(s)
    If you can see the servo you can see the pipe! The pump is on the back of the head. I imagine your servo is full of water and if it is you will need a new servo and master cylinder.
  1. Please Help Rock hard brake pedal
    By corby008 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-03-2009, 05:42 AM
  2. Please Help Brake pedal hard to push and no power below 2000RPM
    By gubby in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-03-2009, 05:39 AM
  3. intermittent hard brake pedal vw passatt
    By shane.hutchinso in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-02-2009, 09:55 PM
  4. Brake pedal going hard (Please help)
    By dubstar81 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-02-2009, 08:41 PM
  5. Please Help brake lights only come on when press pedal hard... is it sensitivity?
    By Smalls in forum Touran - Sharan - Caravelle
    Last Post: 17-07-2008, 01:14 PM
