Thread: temp gauge water leak, fuel leak all sorted
  1. temp gauge water leak, fuel leak all sorted
    a6rom Guest
    right i had the folowing problems and wanted to share the way i fixed them.
    temp gauge would not work no matter how hot the car got, fixed by replacing the temp sensor, original was a square blue 4 pin switch, replacement was square green 4 pin switch from gsf £14 plus 70p for a new washer, i reused the horse shoe clip but be careful as it does fly off and fall where the eye cant see LOL. result, temp gauge works and better mpg, as the 4 pin switch uses 2 pins to feed the gauge and other 2 tell scu what temp car is running, before it was telling it the car is always running cold. now its sorted.
    water leak, initally looked like it comming from the pipe from the water pump to the oil coller but in fact it was the top water flange the plastic part that holds the temp sensor, this was £10 from audi dealer although i later found out gsf do it for £6, on mines the rubber seal which sits between the flange and engine had cracked and was causing the leak. this is sorted now, no more leaks, had to refill system with g12 anti freeze 50/50 ratio, 1.5 litre concentrate from gsf £6.71.
    deisel leak was from the deisel return pipes which sit just under the plastic engine cover on top of the rocker cover, these rubbe pipes persh after time, had them all replaced by local garage £15 parts and labour, no more leaks now.
    ok what went wrong, i over tightened the nuts on the plastic engine cover which twisted the rubber off the mounts, making both mounts useless, got replacement mounts from dealer £5 each.
    now the car runs really nicely and much more smooth it is giving me more mpg but i'm still to calculate an exact figure.
    my car is an 1998 S reg, audi a6 1.9tdi manual 102k, gona hav the oil and filter changed its been 6k miles since it was done, original oil filter from euro car parts £6.71 audi quoted £15 LOL
    5 litres of 10/40 semi synt deisel oil from audi £23, apart from the above work, i had the timing belt and kit replaced, water pump thermosat and other belts, hopefull the cars good for another 150k before i decide its time for a change. very happy with it at the mo, and hope this helps someone whos had similar problems.
  2. Re: temp gauge water leak, fuel leak all sorted
    What is the engine code. IS this PD engine. If so then that is the wrong oil. Regards Peter
  3. Re: temp gauge water leak, fuel leak all sorted
    a6rom Guest
    hi, i dont know the engine code how would i find this out, it's not a pd garage confirmed this. and audi dealer checked with chassis number then gave the oil, so pretty sure its the right stuff.
  4. Re: temp gauge water leak, fuel leak all sorted
    On the ID Label in the service book or on the Label is the spare wheel bay. Regards Peter
  5. Re: temp gauge water leak, fuel leak all sorted
    Jul 2007
    Cheshire, or my A6
    Quote Originally Posted by Peter D View Post
    Won't be PD Peter, it's a 98 model.
    Probably a VE engine.
    I've just put Shell Helix Diesel 10W-40 in my VE engined Octavia, cost about £15 for 5 litres.
  1. WATER TEMP AND OIL GAUGE NOT WORKING - A6
    By A6 trouble in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 08-03-2010, 04:24 PM
  2. A4 Water Temp / Oil Temp gauge
    By Zulu in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-11-2008, 06:24 PM
  3. Please Help Water Leak
    By saj26 in forum Audi A3 - Archive Topics
    Last Post: 27-10-2008, 06:52 PM
  4. water temp gauge
    By sschletter in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 23-02-2008, 05:09 PM
  5. temp gauge and fuel compsumption gauge
    By mikeA4_88 in forum Archive posts
    Last Post: 03-02-2008, 11:23 PM
