Thread: Airbag warning light Golf 5, 2.0TDI, 2005
Results 1 to 8 of 8
  1. Airbag warning light Golf 5, 2.0TDI, 2005
    mikemacro Guest
    Hi, first time on your site so please be patient with me!!
    I am installing an aftermarket device and have removed the cowling aroung steering column to gain access to some wires I need to take signals from.
    In doing so I unplugged the airbag connector (yellow with orange clip) to make access easier. I plugged it back in carefully and it is properly seated however I now have an airbag warning on the display. Is this normal or have I really developed an airbag fault by unplugging and re-plugging the said connector?
    Is there a fix for this or must I go to a VW dealer to have it re-set?
    SECOND QUESTION:
    The aftermarket device needs to tap into the speed pulse (VSS) can anyone please tell me where to find this wire and how to identify it?
    If it is behind the factory radio, can you please tell me how to remove this without damaging the facia?
    Many Thanks,
    Mike M
  2. Re: Airbag warning light Golf 5, 2.0TDI, 2005
    macc70 Guest
    CODE READER U281 - EBAY 25 NOTES INC with instructions
    If you get stuck with it let me know and Ill keep you right (TRY TO)
    This is for the MK5 platform cars Just got mine for the same reason works a treat 2 minute job
  3. Re: Airbag warning light Golf 5, 2.0TDI, 2005
    mikemacro Guest
    Quote Originally Posted by macc70 View Post
    Hi Macc70, thanks for the reply - does the Code reader reset the fault warning as well as tell you what the fault is?
    And - any idea about the VSS pulse - where to pick it up?
    Cheers Mike M
  4. Re: Airbag warning light Golf 5, 2.0TDI, 2005
    macc70 Guest
    Hi light will be reset and code number displayed on reader screen (mine was 01578)
    As for the VSS wiring I dont know You may need to buy a can bus speed sensor You should start with a wiring diagram
  5. Re: Airbag warning light Golf 5, 2.0TDI, 2005
    I had a problem with my Audi A3 airbag light for a different reason though.
    Whilst your air bag light is on they will not operate at all - just so you know!
  6. Re: Airbag warning light Golf 5, 2.0TDI, 2005
    Canada
    If you don't wan to spend anything then, try a member with VAG-com.
    You may not of got a fault if you disconnected the battery first
  7. Re: Airbag warning light Golf 5, 2.0TDI, 2005
    mikemacro Guest
    Hi Macc70, thanks again for your help, and to all the other guys who took the time to reply.
    1/ Can you tell me how to remove the factory radio without damage to facia please?
    2/ Can anyone tell me which is the VSS wire and where it is?
    3/ AND are there any on-line wiring diagrams for Golf 5? (i.e. that are free!)
    Many Thanks All,
    Mike M
  8. Re: Airbag warning light Golf 5, 2.0TDI, 2005
    Canada
    Quote Originally Posted by mikemacro View Post
    https://www.vwaudiforum.co.uk/forum/s...ad.php?t=21273
    Many Thanks All,
    Mike M
    I would recommend buying a Haynes manual, I have the MK5 its got an excellent wiring diagram in it.
  1. Airbag and Emmission Warning lights A6 (2005)
    By pgmabley in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 25-01-2009, 02:25 PM
  2. Question MkV TDI Airbag warning light
    By Steven Wass in forum Golf MK5 - 2004 - 2009
    Last Post: 28-08-2008, 09:19 PM
  3. MK3 AirBag Warning Light
    By Golf-Fiend in forum Golf MK3 - 1993 - 1999
    Last Post: 30-06-2008, 10:14 AM
  4. 2005 2.0tdi multiple warning lights
    By chris96a4 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 21-06-2008, 02:31 PM
  5. Airbag Warning Light
    By TheEggShell in forum Audi A3 - Archive Topics
    Last Post: 07-04-2008, 11:55 AM
