Thread: Golf rear windscreen washer - not much water
  1. Golf rear windscreen washer - not much water
    Aug 2007
    I have a Mk 4 golf on a 2000 plate. Recently I have not been able to get the rear tail gate wash system to give more than a dribble of water. When operating the jet the resevoir pump seems to make a "fluttering" sound with some liquid been also directed to the front windscreen. Can anyone help? Thanks.
  2. Re: Golf rear windscreen washer - not much water
    Southampton, UK.
    I assume you've done the obvious and checked the level of water in the resevoir? You could have a partially deteched or leaking hose on the rear motor. There are plenty of threads. Do a search. If it is leaking, it'll cause problems with all sorts of electrical bits (not just the wiper, door and lights, for example) as the water causes shorting and corrosion. There could also be a blockage.
    Let us know how you get on.
    2003 VW Golf Est 1.9 TDI 130 (gone but not forgotten after 379,000 miles)
    2006 Audi A3 2.0 TDI Sport 140
    2015 Audi A6 Avant 2.0 TDI ultra 190
    2 0 0
  3. Re: Golf rear windscreen washer - not much water
    meathead Guest
    My flow was reduced (ooer) and the problem was a cracked connector where the hose meets the washer motor assembly. Again, just search the forums.
    Take the plastic trim off the tailgate, and get someone to operate the rear washer, and it will be immediatley obvious if you have a leak there, believe me!
  1. Rear washer, water dripping from roof!!
    By Avfc1 in forum Golf MK4 - 1999 - 2004
    Last Post: 25-08-2008, 12:25 PM
  2. Question Rear windscreen washer
    By cornishboy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-07-2008, 08:57 PM
  3. Mk IV Golf - rear washer
    By meathead in forum Golf MK4 - 1999 - 2004
    Last Post: 18-01-2008, 10:55 PM
  4. A4 Avant Rear Windscreen wiper and washer problem
    By maudi25 in forum Archive posts
    Last Post: 18-01-2008, 10:45 PM
  5. Touran rear windscreen washer pipe problems
    By touran wales in forum Touran - Sharan - Caravelle
    Last Post: 13-01-2008, 02:27 PM
