Thread: a3 2000 (x reg) eps warning light and airbag
  1. Question a3 2000 (x reg) eps warning light and airbag
    Feb 2009
    hi just brought a3 1.9tdi 110bhp the car is fitted wiv 18" alloys and my esp warning light is on with exclamation mark in middle?? could this be to do with the alloys not being correct size?? also airbag light stays on?? any ideas?? thanks. andy
  2. Re: a3 2000 (x reg) eps warning light and airbag
    Jan 2009
    fitting 18" wheels will not cause esp light to come on, nor will 18" wheels cause airbag controller light to come on...
    re: airbag controller was probably scanned using vag-com with original cable assembly resulting in hard (unre-settable) fault code - the earlier airbag controllers can be corrupted by vag-com scanning
    if this is case, airbag controller(s) - I have no idea whether (1) airbag or several - must be replaced - this is costly to do...
    re: esp light on continuously - I would lift up car and individually remove each abs & each esp wheel sensors (located on each wheel backing plate) and clean dust off each sensor using dry clean paint brush
    DO NOT disconnect any electrical connectors - if light still on after clearing accumulated fault codes, than
    continuous esp light on usually indicates failed esp control /valve manifold module failure - must be replaced...
    do you have any warranty with this car?
    DO NOT use vag-com to scan again - have audi agent diagnose problems as vag diagnostic device will not corrupt airbag controllers, IF you still have any functioning airbag controllers left
    you either have (4) airbags or (6) airbags depending on trim/build level of your A3 - look in spare tire well for build invoice - small sheet of paper with many 3 digit codings printed on perhaps 12 lines of printing...
    the original owners manual also contains same "build invoice" however I don't know whether you have the car documentation...
    your A3 has (2) serious problems that require soonest attention...
  1. Airbag warning light
    By Redzer in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 09-01-2009, 04:36 PM
  2. Airbag Warning Light
    By garybuk in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 21-11-2008, 10:26 AM
  3. Airbag Warning Light
    By TheEggShell in forum Audi A3 - Archive Topics
    Last Post: 07-04-2008, 11:55 AM
  4. Airbag warning light
    By funkymonkey in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 11-03-2008, 07:25 PM
  5. The airbag warning light
    By Quatrelle in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 21-02-2008, 07:36 PM
