Thread: has any one ever solved this???
Results 1 to 8 of 8
  1. Question has any one ever solved this???
    May 2008
    alright peps here is a scan fom my car any one ever fixed this?
    i'm not that worried about the Interior Monitoring Sensors .
    cheers
    Chassis Type: 1J - VW Golf/Bora IV
    Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
    76
    VIN: WVWZZZ1JZ5W064128 Mileage: 65520km/40712miles
    Address 01: Engine Labels: 038-906-019-ASZ.lbl
    Part No: 038 906 019 KJ
    Component: 1,9l R4 EDC G000SG 5366
    Coding: 00002
    Shop #: WSC 01266
    WVWZZZ1JZ5W064128 VWZ7Z0D1150516
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
    Part No: 1C0 907 379 M
    Component: ESP FRONT MK60 0102
    Coding: 0019970
    Shop #: WSC 01266 785 00200
    Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
    Part No: 1C0 909 605 A
    Component: 27 AIRBAG VW51 01 0008
    Coding: 12855
    Shop #: WSC 01266
    Address 16: Steering wheel Labels: 1J0-907-487-A.lbl
    Part No: 1J0 907 487 B
    Component: Lenkradelektronik 0002
    Coding: 00008
    Shop #: WSC 01266
    Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
    Part No: 1J5 920 946 C
    Component: KOMBI+WEGFAHRSP VDO V23
    Coding: 17414
    Shop #: WSC 00000
    1 Fault Found:
    01336 - Data Bus for Comfort System
    80-10 - Single-Wire Operation - Intermittent[/b][/b]
    [/color]
    Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
    Part No: 6N0 909 901
    Component: Gateway K<->CAN 0001
    Coding: 00006
    Shop #: WSC 01266
    1 Fault Found:
    Address 46: Central Conv. Labels: 1C0-959-799.lbl
    Part No: 1C0 959 799 B
    Component: 6G Komfortgerát HLO 004
    Coding: 00258
    Shop #: WSC 01266
    Part No: 1C2959802A
    Component: 6G Tőrsteuer.FS KLO 0202
    Part No: 1C2959801A
    Component: 6G Tőrsteuer.BF KLO 0202
    Part No: 1C0959811A
    Component: 6G Tőrsteuer.HL KLO 0202
    Part No: 1C0959812A
    Component: 6G Tőrsteuer.HR KLO 0202
    1 Fault Found:
    01135 - Interior Monitoring Sensors
    36-00 - Open Circuit
    Address 56: Radio Labels: 1J0-035-18x-56.lbl
    Part No: 1J0 035 186 D
    Component: Radio YD5 0004
    Coding: 02403
    Shop #: WSC 01266
    Address 76: Park Assist Labels: None
    Part No: 1J0 919 283 A
    Component: Einparkhilfe 0001
    Coding: 00113
    Shop #: WSC 01266
    cleared them and still came back
  2. Re: has any one ever solved this???
    Hi You have a break on one of the can bus wires,no real problem as the system will still work on one wire.Can be a bit of a pig to find the break.
  3. Re: has any one ever solved this???
    May 2008
    so will it cause me any probs wiv vag com ? like trying to change things
    cheers
  4. Re: has any one ever solved this???
    You will have no problems until the second wire breaks
  5. Re: has any one ever solved this???
    May 2008
    cheers kenney any ideas where to look for the broken wire?
  6. Re: has any one ever solved this???
    Iam only guessing now,but i would start with checking the can wires from the comfort control unit to the dash panel insert
  7. Re: has any one ever solved this???
    May 2008
    any one no what colour wires they are?
  8. Re: has any one ever solved this???
    can high is green on orange and can low is brown on orange.
    An idea is to enter the CCU while you are fault finding, address 46 ch 8 group 12
    Check bus
    Bus OK.
    Bus not OK.
    - Visual check of wiring
    Check that connections of relevant current circuit are correctly connected and seated securely whilst simultaneously observing display
    If the display does not change when operating, rectify fault or renew relevant component
    If no changes occur, separate all door main connectors and reconnect one after the other again
    Observe measured value block
    If display changes, renew relevant control unit
    Erase fault memory
    Perform functional check
    Interrogate fault memory again
  1. electrical problem solved
    By zollaf in forum Chat - Anything with wheels
    Last Post: 09-11-2008, 06:24 PM
  2. Important key fob problem solved,it may help others
    By STEWY L in forum Bora - 1998 - 2005
    Last Post: 21-10-2008, 04:03 PM
  3. TDi 2.0 Stalling problem solved
    By TwinCam88 in forum Golf MK5 - 2004 - 2009
    Last Post: 09-09-2008, 07:55 PM
  4. Attention Another MAF mystery solved.
    By Chris714326 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-07-2008, 06:55 PM
  5. Problem solved
    By mbronsell in forum Golf MK4 - 1999 - 2004
    Last Post: 11-01-2008, 08:46 PM
