Thread: Water fills up battery compartment?
Results 1 to 10 of 10
  1. Water fills up battery compartment?
    I have been having this problem for a few weeks, everytime it rains the battery compartment gets filled up with water?
  2. Re: Water fills up battery compartment?
    Hi You will find the Audi similar to the following http://www.weirdlittlebiscuit.com/passat/leak/
  3. Re: Water fills up battery compartment?
    Mar 2007
    9 Post(s)
    its a common problem mate there are 2 drain holes in the battery compartment that get blocked with all kinds of rubbish you need to remove the battery to do a proper job give the holes a good clean i flushed mine with an hosepipe
  4. Re: Water fills up battery compartment?
    134 Post(s)
    2005 Post(s)
    Do a search on here, it is THE most common question on the A4/A6 and Passat. It is the subject of a recall at Audi and cleaning the drains is now on the service sheet but they never do it.
  5. Wink Re: Water fills up battery compartment?
    they say prevention is better than cure,the battery compartment should not fill up with water in the first place,these drain holes are only an aid,the problem lies with the seal which i have been told is a bit of foam which deterioates over time, a freind of mine had the same problem with his x plate a4,audi didnt find it but eventually he did, he used a good quality sealer along the existing foam and that cured the problem,hope this helps.
  6. Re: Water fills up battery compartment?
    Mar 2007
    9 Post(s)
    no mate the design allows water in the drain holes are there for that reason problems only start when these drain holes become blocked
  7. Re: Water fills up battery compartment?
    134 Post(s)
    2005 Post(s)
    Don’t listen to what mates tell you; listen to those that have been working on VAG products long before the designers of the A4 left kindergarten. The battery compartment is deigned to fill up with water, it is the plenum chamber and so is the air intake for the heating system. The foam seal at fault is around the base of the pollen filter housing and water ingress around this seal would not be an issue if the drains below the battery and servo were kept clear as is clearly stated on the Audi service sheets. Also not parking under trees/hedges/foliage would help if this was possible.
  8. Re: Water fills up battery compartment?
    fair enough,but iam speaking from others experience,my mates car filled up with water as far as the rear seat wells,audi could not find the fault but sealing up the battery compartment cured the problem.
  9. Re: Water fills up battery compartment?
    [quote=fatfighter;318038]fair enough,but iam speaking from others experience,my mates car filled up with water as far as the rear seat wells,audi could not find the fault but sealing up the battery compartment cured the problem.
  10. Re: Water fills up battery compartment?
    Mar 2007
    9 Post(s)
    hi mate i think we are getting our wires crossed here i dont think audi sealed the battery compartment or whoever. i done a job on an a3 once that was letting water in even though the battery compartment was bone dry i removed the pollen filter tray completly from the car then put a thick bead of silicon sealant around the edge of the opening in the bulk head replaced the tray and bolted it down this solved the problem
  1. Question Water in Battery Compartment
    By taffrichards in forum A2
    Last Post: 28-01-2009, 09:30 PM
  2. Please Help water in battery housing
    By benella in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-08-2008, 06:00 PM
  3. Water in boot amplifier compartment
    By n_c in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 31-07-2008, 12:07 PM
  4. water collecting in battery compartment
    By Topcat65 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-06-2008, 11:53 PM
  5. Water hanging under battery
    By vroooOOOM in forum Reviews & Recommendations of Dealers & Independant Garages
    Last Post: 17-06-2007, 10:10 PM
