Thread: Longlife service lasted only 12 months
  1. Longlife service lasted only 12 months
    Feb 2009
    I drive a 52 Reg 225 s-line Quattro. I purchased the car in Oct 2007 and had a long life service at an Audi dealer in Feb 2008 at a mileage of 32454. I have only covered 1500 miles in the 12 months since the service, fairly evenly spread and generally NOT including short journeys. After about 7 months the warning started to tell me I would need a service in 800 miles time. This has reduced linearly until, after almost exactly 12 months, it says I now need a service. I contacted the dealer to ask if they might perhaps have incorrectly reset the system based upon a 12-month service. They said this was very unlikely and that the reason was that the long life oil is not deigned for such a low milege - it will have degraded as a result, the sensors will detect this and that is why it is saying a service is required. (They say you need to do at least 2000 to 3000 miles a year to avoid this.) They suggest that an oil change will probably cure the problem, but I spent almost £70 in oil alone just 1500 miles ago, and another oil change at their prices will be £100+ with labour. I also wonder about the actual oil their service bill says they used and whether it is long life - it's described as "SHELL HELIX ULTRA 5W-3", a description I have been unable to substantiate so far using google searches. If anyone has any views on whether this idea that long life oil degrades with low usage and/or whether this spec. of oil is indeed long life, or has any other advice, I would be most grateful. Many thanks. Karen.
  2. Re: Longlife service lasted only 12 months
    Jan 2009
    towcester northants
    sounds like they set car service indicator up as yearly 10k
  1. Question about Oil light two Months after service
    By Dec in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-11-2008, 11:57 PM
  2. longlife service?
    By barryonline in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 17-08-2008, 03:12 PM
  3. Question Longlife Service
    By skybird28 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-05-2008, 05:48 PM
  4. Am I on longlife service
    By 12bamf in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-01-2008, 09:27 PM
  5. Is there a service interval in Months for MK4
    By d@ve in forum Golf MK4 - 1999 - 2004
    Last Post: 26-01-2007, 04:45 PM
