Thread: Dash Warning Light?
Results 1 to 10 of 15
  1. Question Dash Warning Light?
    Feb 2009
    Hi all,
    I have a very simple question. The warning lights on my Leon 53 plate has a flashing symbol like a spring coil. One continuous line with 2 loops.
    I can't find it in the hand book, can anyone tell me what it is and what does it mean?
    Thanks,
    Graeme...
  2. Re: Dash Warning Light?
    Chester-le-Street, United Kingdom
    Quote Originally Posted by nedflounders View Post
    Hi all,
    Thanks,
    Graeme...
    on the tdi it's the glowplug light. when it flashes it usually means a problem
    with the brake lights and/or pedal switch.
    regards,
    stewy.
    first time i was up a ladder i was down a well
    4th cog,--two to go
  3. Re: Dash Warning Light?
    Feb 2009
    Hi Stewy,
    I'll check those if I can.
    Thanks,
    Graeme.
  4. Re: Dash Warning Light?
    Jul 2008
    marske,cleveland
    hi stewy and graeme,my friends 55 plate leon fr tdi has just done exactly whats being described in your posts.ive let him know,but he wants to know what he should be looking for to try and sort the problem.he daren't drive the car with the brake lights being dodgy,and has to wait till wednesday for a mechanic to check it out.thanks lads.
  5. Re: Dash Warning Light?
    Feb 2009
    Hi Rolfather,
    I checked the brake lights and found they weren't working so took it to work to try and fix.
    However I noticed that the dash warning light had stopped flashing.
    After Stewy gave me a couple of ideas I would guess mine was a sticky switch.
    I didn't need to check it though, and don't know how too.
    Maybe Stewy could help?
    Cheers,
    Graeme...
  6. Re: Dash Warning Light?
    if the glow plug light is flashing,first check the brake lights,lower and high level leds.
    if the lower lights are out,check the bulbs.
    if the bulbs are ok,change the switch on the brake pedal,it's about £8-£10.
    easy job really,but it has been known to smash a switch whilst fitting it.
    you just need to go easy,
    regards,
    stewy.
    4th cog,--two to go
  7. Re: Dash Warning Light?
    Jul 2008
    marske,cleveland
    thanks lads,i'll pass on the info.cheers
  8. Re: Dash Warning Light?
    Jul 2008
    Quote Originally Posted by rolfather View Post
    I take it you checked the fuse too
  9. Re: Dash Warning Light?
    Feb 2009
    I thought the fault had gone but it has come back.
    I have checked the switch it is ok.
    Fuse is ok. Got 12v to pedal switch and have shorted out to eliminate it completely.
    I still can't get a supply to the lamps?
    I have a Tow Bar fitted, does the wiring go to the brake lights then Tow Bar or Tow Bar then lights?
    Thanks,
    Graeme...
  10. Re: Dash Warning Light?
    May 2009
    Glasgow
    I jus tbought an 09 plate FR550 and with only 400 miles on the clock i have had this exact problem, since the car is still under warrenty i am taking it back into the garage this afternoon. but it is good to have an idea of what could be the cause before i go into the garage with it - lessens the chance of the mechanics giving me a load of bull about it!
    cheers for the earlier replies.
  1. Please Help ESP dash warning light
    By weejp in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-10-2008, 06:13 PM
  2. Dash warning light
    By Lagerman in forum Beetle 2000-
    Last Post: 24-05-2008, 06:23 AM
  3. dash warning light T4
    By andrew pearce in forum The Commercial Range
    Last Post: 24-03-2008, 09:38 PM
  4. Stop Warning Light In Dash
    By Passatguy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-11-2007, 09:23 AM
  5. Dash Warning Light
    By lordcakes in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-06-2007, 08:13 PM
