Thread: Understanding vagcom results
Results 1 to 10 of 10
  1. Understanding vagcom results
    Sep 2007
    Liverpool
    After finally sorting out vagcom & interface, & charging my old laptop with serial port, IO manages a scan on my Passat. Threw up a few faults:
    MAF - open or short to ground
    Air flow flap positioning motor faulty
    coolant temp sensor open / short to ground
    alarm horn internal supply voltage.
    Most concerning are the MAF & Coolant temp sensor.
    I pressed the clear results tab thinking this clears the faults in the ECU, after repeating the scan I got the same results.
    Is this how the faults are cleared from the ECU or is it some where else, or is it that all these faults are genuine & still there????????????????????
  2. Re: Understanding vagcom results
    7 Post(s)
    You need to post up the full code (copy and paste out of VCDS)
    Are the faults intermittant, if so, clear them and see if they come back in the first instance.
    But do post up the full codes for a better answer.
    [edit]
    It depends what version / cable you have on how you clear faults.
  3. Re: Understanding vagcom results
    Norfolk
    Quote Originally Posted by PETER G View Post
    If you press clear, you clear the fault codes. BUT as soon as you switch on or start the engine they will come straight back if you haven't fixed the faults first.
  4. Re: Understanding vagcom results
    Jul 2008
    Sorry - what was the original reason you were reading with Vag-com or was it just aa check up?
  5. Re: Understanding vagcom results
    Sep 2007
    Liverpool
    Quote Originally Posted by BigCol View Post
    [edit]
    The version I have is 311-2 & I am using a KKL interface, hope that is right.
  6. Re: Understanding vagcom results
    Sep 2007
    Liverpool
    Quote Originally Posted by martin1810 View Post
    Sorry not made myself clear, I have been getting poor MPG for a while now, after reading a number of threads on here I unplugging the MAF to see any difference, so I knew it would throw that up as a fault also some time ago the temp gauge was irratic, but the temp gauge now works ok. I thought the clear faults would clear these faults if they where due to "one off interfearances", but it seems they may be proper faults?????????
  7. Re: Understanding vagcom results
    Sep 2007
    Liverpool
    Quote Originally Posted by cazyp View Post
    Getting poor MPG & due a service.
  8. Re: Understanding vagcom results
    Norfolk
    Sorry impossble to say with your set up. I assumed you were using a proper vag-com set up. Lots of people have found cheap cables and software to not work correctly.
  9. Re: Understanding vagcom results
    Jul 2008
    Have you replaced the CTS?
  10. Re: Understanding vagcom results
    Sep 2007
    Liverpool
    I take it the CTS is coolant temp sensor, if so it has shown up as a fault (open/short to earth) so will be replacingvery soon.
  1. understanding Vag com fault findings
    By Grover2000 in forum VCDS - General Questions
    Last Post: 29-04-2008, 12:51 PM
  2. Update/results on new Maf !!!
    By cbrpaul in forum Chat - Anything with wheels
    Last Post: 22-09-2007, 07:12 PM
  3. what were the remap results
    By fozzie in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-09-2007, 07:24 PM
  4. My Vag-Com Results - Help Please
    By craigbeal in forum Audi A3 - Archive Topics
    Last Post: 30-07-2007, 05:14 PM
  5. GTI Festival - The Results
    By danny allen in forum Shows & Events
    Last Post: 12-07-2007, 08:26 AM
