Thread: Drivers door has dropped
  1. Unhappy Drivers door has dropped
    Feb 2009
    - wondering if anyone can help, i ve got 3dr mk3 golf and the drivers door has dropped so the lock does not line up and every time you shut the door you have to lift it ok went your out the car pain when your inside
  2. Re: Drivers door has dropped
    Jan 2009
    towcester northants
    use a deep socket between the hinge and the body but be carefull as you use the wrong size you can damage the bodywork by the hinge
    first make sure you have no play in hinge
  3. Re: Drivers door has dropped
    Feb 2009
    ok i'l have a look, how easy is it to replace hinges if needed to? how much are they? just a rough idea
  4. Re: Drivers door has dropped
    Feb 2009
    hi all- new to the forum-looks good,
    i am trying to make our old 3 door golf look presentable again.
    1995 3-door diesel.
    About the door- thats something i just managed to fix-
    two 2mm washers fitted between the bottom hinge and the door and the door
    closes like new again!!
    good luck
  1. Changing door hingers,door dropped
    By Smartalex in forum Golf MK4 - 1999 - 2004
    Last Post: 20-12-2008, 03:43 PM
  2. Drivers door has dropped!
    By magicmillerman in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-04-2008, 04:41 AM
  3. Drivers door dropped
    By Marco34 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 11-04-2008, 10:43 AM
  4. 05 Polo passenger door dropped. Hows yours?
    By skodaescapee in forum Polo - Derby - Lupo - Fox
    Last Post: 17-03-2008, 06:33 PM
  5. Golf - Window dropped into driver's side door!
    By Rachel in forum Golf MK4 - 1999 - 2004
    Last Post: 13-11-2007, 09:29 PM
