Thread: a4 tdi, limp mode and hiccups
  1. a4 tdi, limp mode and hiccups
    Dec 2008
    ive got a 1995 tdi 110, when i first got the car it would constantly go into limp mode, i took a look at the engine and found that one of the intercooler pipes was split, so after a easy fix all was fine, but now when you accelerate hard and get to about 40+ its will hold back for 3 secs and then keep doing it every 5mph+ and also when you accelerate up hills some time it will go straight into limp mode!!!!
    ive had a look around and cant find anything!
    the car was serviced last july and has had a new MAFM!
    also is there anyone in the plymouth area that has VAG.com? or know of any garages?
    thanks!
  2. Re: a4 tdi, limp mode and hiccups
    Jun 2007
    Dont want to be the doom monger but I had the same symptoms on my A4 and it turned out to be the turbo fins were sticking due to a knackered bearing,luckily I got a new turbo under the warrenty but it would of cost around £800.As the bearing is a mechanical fault and not an electrical one it may not show up on the vagcom.
  3. Re: a4 tdi, limp mode and hiccups
    Dec 2008
    i was thinking that it was the turbo, as its makes a wierd whistle noise not like normal turbo whistle but more like a wooshing noise when boosting, did yours ever make that kind of noise aswel? thanks for the reply!
  1. Limp mode - think I'm going to cry!! lol
    By MikeMc in forum Golf MK4 - 1999 - 2004
    Last Post: 22-04-2009, 09:47 AM
  2. Limp mode i think?
    By longmanjon in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-02-2009, 06:07 PM
  3. Limp Mode
    By shuggy2005 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-10-2008, 08:35 PM
  4. Limp Mode??!!??
    By feroz28 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-03-2008, 10:24 PM
  5. Limp Mode...
    By milenia in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-10-2007, 03:57 PM
