Thread: Slight hissing when accelerating
  1. Slight hissing when accelerating
    Dec 2007
    Eyup Lads/Ladies,
    I noticed the other day on my mark 4 golf gti tdi that when i accelerate and the turbo kicks in there is a bit of hiss. It almost sounds like a quite dump valve. It's not loud I just wanted to know if this was normal or I might have a slight leak in one of the hoses Any light shed on this would be kl Cheers
  2. Re: Slight hissing when accelerating
    Apr 2007
    N.Ireland
    You normally can hear a slight hiss when the turbo is spinning up but if you think its unusually loud then there may be a slight boost leak. If the car is running fine with no noticeable loss of power or no excessive smoke from the exhaust when under acceleration then its probably nothing to worry about
    Golf GTD 2.0 DSG (ACC | Winter Pack | 18" Vancouvers | RCD510 | Parking Sensors, Rear Camera & Park Assist | Cruise Control | Flat Tyre Indicator | Luxury Pack | Rear Airbags)
  3. Re: Slight hissing when accelerating
    Aug 2008
    Wigan
    9 Post(s)
    Look at the intercooler hose - you can see it under the front offside wing in front of the wheel arch. It's more easily accesible if you undo the bottom three whell arch liner screws (torx head). If you can get somebody to rev the car while you look and listen you may find the hiss is coming from there. I agree with the above comment - I did a 500 mile round trip to London with it hissing and still got high mpg and no noticeable power loss. I had it put back on when I got back. Also look at the post by bparsons1984 on 29-01-2009 for more about this problem.
  4. Re: Slight hissing when accelerating
    Dec 2007
    Cheers lads, I will give it a look over at the weekend. Nice to know its nothing major
  1. Question Air Con hissing
    By old boy walters in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-07-2009, 09:22 AM
  2. hissing noise
    By firefly in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-07-2008, 06:55 PM
  3. hissing type noise when accelerating
    By bll2109 in forum Golf MK4 - 1999 - 2004
    Last Post: 19-02-2008, 02:21 PM
  4. Hissing Pipe , but now dry
    By doug.howsie in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-11-2007, 11:08 PM
  5. 1.8t hissing noise
    By Scooterist007 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-10-2007, 08:46 AM
