Thread: Whirring sound front end
Results 1 to 8 of 8
  1. Whirring sound front end
    Aug 2007
    Hook Hampshire
    21 Post(s)
    This weekend I noticed a whirring sound that sounds like a bearing has gone. It is comming from the front end at low down, centre to near side. The sound changes as the revs increase, but its difficult to place exactly where it is. I also noticed that the voltmeter took about 30 seconds to reach 14v when I started the car this morning. I am sure it reaches this figure within a few seconds normally.
    Given that the alternator is at the OS of the car, I am confused. I will need to start stripping the front end, but any ideas from anyone.
    Thanks. Cam belt replaced 30K miles ago
    Audi A7 3.0TDi 2011 160k miles, engine code CLAB 204bhp 2WD
  2. Re: Whirring sound front end
    london/ UK
    Either the relay roller, tensioner or the water pump...
  3. Re: Whirring sound front end
    Aug 2007
    Hook Hampshire
    21 Post(s)
    Thanks Chris, What is the relay roller?
    Having taken the floor cover off, I think the noise is comming from the aircon compressor but can't be sure. I will have to remove the front end and take the belt and see if the sound disappears.
    Job for the weekend. Hope that its ok for my 400 mile round trip up north.
    Anyone had this experience.
  4. Re: Whirring sound front end
    Aug 2007
    Hook Hampshire
    21 Post(s)
    It was the relay roller tensioner for the aircon compressor belt. Adams24 does it again
  5. Re: Whirring sound front end
    Mar 2009
    i've got the same problem, and my mechanic thinks its the power steering pump.
  6. Re: Whirring sound front end
    Jul 2007
    Cheshire, or my A6
    Quote Originally Posted by halfpint View Post
    Is the poly V belt at the front of the engine flapping and vibrating when you turn to full lock while stationary?
    That is something you can check yourself.
  7. Re: Whirring sound front end
    Aug 2007
    Hook Hampshire
    21 Post(s)
    I thought that as well, but luckily it was only the tensioner. About £30. When I removed the tensioner, it rotated freely but you can hear a sound from it. I reckon the power steering pump will be a lot more expensive. best of luck.
  8. Re: Whirring sound front end
    Jul 2007
    Cheshire, or my A6
    Quote Originally Posted by shabazmo View Post
    I'm just wondering if halfpint's mechanic has diagnosed it correctly...
  1. 02 polo knocking sound at front
    By n.howard in forum Polo - Derby - Lupo - Fox
    Last Post: 12-01-2009, 10:08 PM
  2. Whirring Sound!!
    By poloman in forum Polo - Derby - Lupo - Fox
    Last Post: 06-06-2008, 01:22 AM
  3. whirring sound at 80mph
    By blackhove in forum Golf MK4 - 1999 - 2004
    Last Post: 06-09-2007, 04:09 AM
  4. Front Fog lights on A4 causes Horn to sound
    By LIAMMC in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-06-2007, 01:05 AM
  5. Slight Tapping, whirring sound
    By Whitie in forum Archive posts
    Last Post: 10-02-2005, 10:30 AM
