Thread: What no more Longlife 2 oil ??
Results 11 to 20 of 26
  1. Re: What no more Longlife 2 oil ??
    Coventry
    I use this - ELF EVOLOUTION CRV 0w - 30
    PHOTOPRODUCTSDESCRIPTIONSPECIFICATIONDocuments ELF EVOLUTION CRV 0W-30 Synthetic technology premium oil for Gasoline and Diesel engines.Specially formulated to reduce Volkswagen engine fuel consumption.Its properties improve the efficiency of engines with injection pumps.
    ACEA A5/B5
    • VW 503.00 / 506.00 / 506.01
    Product Data Sheet
  2. Re: What no more Longlife 2 oil ??
    Sep 2007
    UAE
    I've also asked Castrol - the manufacturers of Longlife SLX and this is the reply today:
    The EDGE 5W-30 meets the latest LongLife III specifications ( 504 00 / 507 00 ) and is backwards compatible with LongLife II so VW dealers will now be using the latest LongLife III specifications in place of the LongLife II and this is quite acceptable.
    LongLife III supersedes the LongLife II in all but some R5 engines and is miscible with LongLife II so you can use for top up and refill
    Kind regards
    Lubricants Automotive - Europe Region
    Lubricants Technical Advisor
    So i'm happier now than I was yesterday. A thought did cross my mind: most PD TDI's must be around 3 years old by now, do VW care anymore if the engines start to deteriorate if they are all out of warranty? The above email disproves this.
  3. Re: What no more Longlife 2 oil ??
    Canada
    Quote Originally Posted by GOLFMK5GTTDI View Post
    ACEA A5/B5
    Product Data Sheet
    I would stick with castrol, they ddi develope th oil with VW
    Don't beleve the marketing hipe
    VW Tiguan 4motion 2.0T 2015 - Awesome snow churning 4x4 GTI 😉
  4. Re: What no more Longlife 2 oil ??
    Nov 2006
    Quote Originally Posted by kimsue View Post
    non hardened camshaft
    No such thing. Castrol technical are talking nonsense.
  5. Re: What no more Longlife 2 oil ??
    Halfords have a long life oil that they said was ok for the 2004 Touran 19.TDI, I am worried now that they have not picked up that there is a diference in any specs for the longlife oils.
    I will have to pop back in to see if the oil is my book says 506 01 is 507 00 ok as well?????
  6. Re: What no more Longlife 2 oil ??
    May 2007
    Sorry - just come to this thread after a long time off forum (no I haven't been inside....)
    If anyone still needs some SLX II I have an unopened litre (for a small consideration to include postage) - please PM me
  7. Re: What no more Longlife 2 oil ??
    #17
    Aug 2008
    i recently had a service on my van. the oil i should be running on is 506.01 longlife. my service receipt says castrol slx longlife III has been used. does anyone know the spec of this oil, i cant seem to find it on castrols website
  8. Re: What no more Longlife 2 oil ??
    #18
    Jun 2006
    Dorset
    Having used up the last of my stock of Castrol SLX LongLife II, I emailed Opie Oils, who confirm that, whilst they stock a VW 506 01 oil by Fuchs, oils to VW 507 00 is also fine. I also Googled and found this 2007 document on the VW UK website:
    http://www.volkswagen.co.uk/assets/c..._servicing.pdf
    which confirms VW 507 00.
    Sharan 1.9TDi 2002
  9. Re: What no more Longlife 2 oil ??
    #19
    Jun 2009
    York yorkshire
    I went to my dealers to get some longlife oil to top up my Golf.. I noticed they gave a different make of oil. When I asked they said the original oil was no longer supplied and they were using Mobil 1 ESP Formula 5W-30W.. After seeing your comments I checked the back of the oil bottle.. it says..
    Recommended for applications requiring* VW502 00 / 503 00 /503 01 /505 00 / 506 00 / 506 01 (*all VW engines with exception of Unit Injector TDI without Longlife Service and without DPF between 1999-2003 and R5/V10-TDI before model year 2006).
    I don't know if it makes sense to you, I've copied it straight from the bottle, missing out foriegn translations.
    My 2004 1.9TDI Golf has almost reached 100,000 miles.. and done almost 10,000 miles since it's last service... seems fine.. fingers crossed :-)
  10. Re: What no more Longlife 2 oil ??
    #20
    wiltshire
    hi guys plz excuse all my dumb questions,
    from reading through the link below i'd guess that the 507.00 spec oils replace previous grades and are suitable for almost all diesel engines includeing pd's & those with dpf's
    with the exeption of
    namely 5 cylinder & v10's ?
    the castrol ' right oil 4 my car' page-
    http://www.castrol.com/castrol/ifram...tentId=7044829
    suggests;- edge turbo diesel 5w-40.
    for my bus giving engine as sharan 1.9 tdi pd,-auto (66-85kw)
    log book states engine number auy 313...........
    am i safe in assumeing 507.00 spec oil is the way to go?
    btw, i can understand how the wrong grade damages pd engines,
    how exactly does the wrong grade damage dpf's ?
    VW golf mk3 1.9DL estate & it is a state
    its falling apart faster than i can fix it, an mot pass will be a bloody surprise
  1. LONGLIFE SERVICE LIGHT
    By Lee Toone in forum Archive posts
    Last Post: 05-09-2007, 09:56 AM
  2. Longlife service after 9000 miles!?!
    By Bassman in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-06-2007, 05:27 PM
  3. A3 2.0T Longlife Service? Dirty oil....
    By mega_stream in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 19-04-2007, 11:57 AM
  4. Quantum Longlife Engine Oil (0W-30)
    By Pimped-Passat in forum Passat - Archive Topics
    Last Post: 23-03-2007, 07:42 PM
  5. LONGLIFE SERVICE...
    By mkpp786 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 21-01-2007, 10:08 AM
