Thread: Airbag control module location
  1. Airbag control module location
    Feb 2009
    Had the airbag light on my 1999 A4 1.9TDI come on for no apparent reason so i invested in a scan reset tool which old me that the likely problem was that the control module for the airbag was faulty so it looks like its goin to need replaced but the trouble is i dont know here to look for it, i reckon its mounted under the dashboard somewhere but dont want to go pulling the whole thing to bits if I dont need to, anybody any idea where to look for it?
  2. Re: Airbag control module location
    Canada
    Its infront of the gear change. you need to remove the console and maybe the radio to get at it. I've just Done my Golf MK5 luckly VW moved it and i only had to remove 2 pieces of plastic
    You will need to code in the new one, so make a note of it before removing it.
    Rob
  3. Re: Airbag control module location
    Feb 2009
    when you say I need to code the new module in what does that involve and where do i find the code?
  4. Re: Airbag control module location
    Canada
    If you have scanned your car you should have a report like this
    Address 15: Airbags Labels: 1K0-909-605.lbl
    Part No SW: 1K0 909 605 R HW: 1K0 909 605 R
    Component: 38 AIRBAG VW8 018 2200
    Revision: 02018000 Serial number: 0038MD06SWZI
    Coding: 0013112
    Shop #: WSC 01269 785 00200
    7 Faults Found:
    00003 - Control Module
    014 - Defective - MIL ON
    01222 - Crash Sensor Side Airbag; Passenger Side (G180)
    The bit in bold is the adaption code, this tells the Airbag ECU how many airbags what type etc. you need to adapt this code on the new module to the same value as read by your code scan
    does that make sense?
  5. Re: Airbag control module location
    Feb 2009
    yeah its all starting to make sense just need to make sure i get the right module as theres an infinite variety of different ones but I've got the part number so should be able to track one down, thanks again!
  1. Please Help Airbag Module/ECU
    By Abbs985uk in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-12-2008, 11:52 PM
  2. Mk3 GTI airbag module
    By spainy in forum Golf MK3 - 1993 - 1999
    Last Post: 23-05-2008, 04:36 PM
  3. Replies: 7
    Last Post: 07-04-2008, 09:00 PM
  4. Airbag module
    By funkymonkey in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-03-2008, 11:37 AM
  5. TT Airbag ECU / SRS Control Unit Location
    By gilesbennet in forum TT - 8N Forum - 1998 - 2006
    Last Post: 14-02-2008, 10:01 PM
