Thread: Audi Coupe - broken air blower and water in footwells and Oil pressure gauge
Results 1 to 8 of 8
  1. Audi Coupe - broken air blower and water in footwells and Oil pressure gauge
    Feb 2009
    I've looked at a coupe where the blower works on the highest setting but not on the other settings and carpet is wet in the front footwells which I think is related to the heater/blower problem. Is this usual for 1996 N Coupes and what is the fix for it?
    Also, the oil pressure gauge flies straight up to the maximum it can - what is that a sign of or is that normal? I checked the dip stick and the oil level looked fine on that.
    Cheers. Emgee
  2. Re: Audi Coupe - broken air blower and water in footwells and Oil pressure gauge
    Mar 2008
    High Wycombe
    I think that the blower only working on high is likely to be a broken resistor pack. Lower speeds are controlled by the switch having a series of resistors, and when these fail, then there's no current on that setting.
    My coupe always used to run high oil pressure at initial startup, but then settle down after a few minutes as the oil heated up. I don't think it should shoot right up to maximum though.
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  3. Re: Audi Coupe - broken air blower and water in footwells and Oil pressure gauge
    Feb 2009
    Any thoughts on where the water is getting in - door seals? the carpets are very damp.
  4. Re: Audi Coupe - broken air blower and water in footwells and Oil pressure gauge
    Feb 2009
    Quote Originally Posted by Emgee View Post
    I read on another thread that water can pour in via the air pollen box if the seal is perished. Can anyone advise what the fix is for this - just use silicone?
  5. Re: Audi Coupe - broken air blower and water in footwells and Oil pressure gauge
    Dec 2008
    I had the water in footwell problem, which was cured by checking / fixing the seal for the bonnet pull under the dash. Mine was comlpetely unseated allowing water to run through from the engine bay into the cockpit. This seems a common problem with an easy fix.
    Hope this helps,
    J
  6. Re: Audi Coupe - broken air blower and water in footwells and Oil pressure gauge
    Gravesend, Kent
    [quote=NickPicks;314754]I think that the blower only working on high is likely to be a broken resistor pack. Lower speeds are controlled by the switch having a series of resistors, and when these fail, then there's no current on that setting.
    quote]
    There is also a thermal fuse on the resistor pack. Mine had failed and so the fan only worked on the high setting. I bought a new thermal fuse from Maplins and all is now OK.
    G.
    Fire Up The quattro!!!!
  7. Re: Audi Coupe - broken air blower and water in footwells and Oil pressure gauge
    Feb 2009
    Quote Originally Posted by upliftin View Post
    Hope this helps,
    J
    I have checked the bonnet release and the area had lots of leaf sludge in there which I have cleared. The grommet seems to be fine but the problem with water in the footwells is on the passenger side as well. Any ideas why it is wet over there (no sunroof on the car)?
  8. Re: Audi Coupe - broken air blower and water in footwells and Oil pressure gauge
    Gwent
    Dare I say, heater matrix leaking?
    doorseals,
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  1. Water in Footwells
    By leeroybrown in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-05-2008, 08:32 PM
  2. Water in Front Footwells yes again !!! Audi Cabriolet
    By mikie mike in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 21-11-2007, 03:39 PM
  3. Water in footwells
    By SJR100 in forum Beetle 2000-
    Last Post: 05-06-2007, 10:37 AM
  4. Audi Coupe Fuel Gauge Problem
    By AUDIMAN in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 13-05-2007, 11:51 PM
  5. Audi Coupe rad fans & temp gauge
    By john493 in forum Archive posts
    Last Post: 13-11-2006, 01:49 PM
