Thread: Smokey 57 Passat 1.9TDi
  1. Smokey 57 Passat 1.9TDi
    Feb 2009
    Can anyone help?
    Recently bought secondhand 57 Passat 1.9TDi. All seemed fine except recently starting in cold morning feels very rough and kicks out lots of smoke. After a couple of mins is fine and runs well all other times with normal smoke. Garage is a bit stumped and says there is no diagnostic issues. Has put additives in the oil and has changed some kind of switch but to no avail. Any ideas????
  2. Re: Smokey 57 Passat 1.9TDi
    Norfolk
    What colour is the smoke. Black or white. Too much white smoke usually means faulty glow plugs.
  3. Re: Smokey 57 Passat 1.9TDi
    Apr 2007
    France
    12 Post(s)
    Try waiting 5 seconds after the glow plug light goes out and see if it smokes.
    What sort of mileage has it done?
    2006 (Dec.) B6 2.0TDi 140 Confort | Moka anthracite nacré | CControl | Highline MFD | Chrome Grill | Meta Targa rear parking sensors | Debadged
    1996 Laguna 2.2D
    1977 MGB roadster
  4. Re: Smokey 57 Passat 1.9TDi
    if its smokey and seems like its misfiring and only does it in the morning or after several hours of not being used it could be air in the fuel lines. have had this before on a peugeot 306 dturbo and a mondeo td the non return valve in the fuel line was at fault both times. the ford garage put in a clear fuel line under the bonnet so you could tell when the fuel had run back into the tank. they just fitted a non return valve into the fuel line which cured the fault.
    the peugeot was a faulty seal at the fuel tank end.
  5. Re: Smokey 57 Passat 1.9TDi
    Derry
    Mine doesn't smoke at all when its cold. There is just a slight smell of diesel in the garage when I start it up in the morning, but thats about it, theres no visible evidence of smoke
    2006 B6 Passat 1.9TDi 105 | 35k | Deep Black Pearlescent | 18" OZ Superturismo Rims | Chrome Grill | 35% Tinted Rear Windows | Boot Lip Spoiler | Debadged
  6. Re: Smokey 57 Passat 1.9TDi
    Feb 2009
    Thanks for replies guys. For info the smoke is worryingly blue/white. Car mileage is 25k so not much really.
  7. Re: Smokey 57 Passat 1.9TDi
    Derry
    Whitehall, you could also try Millers Diesel Power Sport 4 to clean out the fuel system. I've been using it for over a year and there has been a decrease in the black smoke. You can get if from Halfords. But as yours is blue/white it may be more serious. Take it to another dealer or even an independent VW/diesel specialist for a second opinion.
  8. Re: Smokey 57 Passat 1.9TDi
    Norfolk
    Whitehall. What's the oil level doing. A hint of blue in the smoke is only a problem if the oil level is dropping dramatically. The blue being oil. Can you leave the car with your garage over night so they experience a cold start. It might be worth running some fuel cleaner through it as Spudrig says, in case one of the injectors is letting in too much fuel on start up.
  9. Re: Smokey 57 Passat 1.9TDi
    Apr 2007
    France
    12 Post(s)
    ..... in case one of the injectors is letting in too much fuel on start up.
    Yep, my guess is its unburnt fuel.
    1996 Laguna 2.2D
    1977 MGB roadster
  1. 2002 Passat TDi 130BHP - Smokey & Rough for 15secs when cold!
    By noelr in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-05-2012, 04:08 AM
  2. Please Help My first VW. Passat S 1.9TDI 105
    By k2jamrock in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 16-02-2009, 08:57 PM
  3. Question 1999 Passat 1.9tdi
    By dryerman in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-12-2008, 09:15 PM
  4. Passat 1.9tdi se accelerate on it own
    By newboy999 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-01-2008, 06:35 PM
  5. VW passat 1.9tdi accelerate on its own
    By newboy999 in forum New Member Introductions
    Last Post: 06-01-2008, 10:00 PM
