Thread: Experts.... Easiest way to remove mk4 golf front spring?
  1. Experts.... Easiest way to remove mk4 golf front spring?
    Jan 2009
    Hello
    Just replaced the rear springs with a 40mm drop. Come to do the front and its causing some confusion. Im guesing i got to take the suspension leg off?....which means droping the subframe and disconnecting the ARB? Then undoing the top nut under the bonet?
    Any help here wud be great....first time ive done this job
    cheers
  2. Re: Experts.... Easiest way to remove mk4 golf front spring?
    7 Post(s)
    I'd suggest first of all getting a manual, even a Haynes, that will give a step by step guide.
    The hardest part of doing this is splitting the hub where it clamps round the base of the strut. VW have a special tool but a large cold chisel and lump hammer will do the trick although a bit brutal.
    Before you start dismantling under the wheelarch though, make sure you have the proper tools for undoing the top nut in the engine bay. A sparkplug socket and allen key are probably the best combo. Otherwise you will need a deeply offset ring spanner and allen key to get down on the nut.
  3. Re: Experts.... Easiest way to remove mk4 golf front spring?
    Jan 2009
    Thanks for the advice....iv found a couple of articles the net of previous attempts at this from others guys....theyre pretty detailed and theyl do the trick. Iv also got hold of an imperial swan neck spanner that fits the strut top nut perfectly so with this and the allan key, il get the leg off.
    Cheers for the help
  4. Re: Experts.... Easiest way to remove mk4 golf front spring?
    Jan 2009
    Job done. Nice and easy. Even managed it without spring compressors.
  1. Remove Front Seats MK4 Golf
    By MathewRB in forum Golf MK4 - 1999 - 2004
    Last Post: 11-01-2009, 02:24 PM
  2. Please Help easiest way of changing front shocks on a B5 ?
    By trevMk2 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-01-2009, 06:06 PM
  3. Replies: 3
    Last Post: 17-01-2008, 01:34 PM
  4. how to remove front bumper on mk4 or 2003 golf please help
    By palolz in forum Golf MK4 - 1999 - 2004
    Last Post: 16-01-2008, 05:26 PM
  5. How to remove a front bumper cover golf 01
    By timbo962 in forum Archive posts
    Last Post: 16-01-2007, 09:55 PM
