Thread: Retrofitting RS4 Multifunction steering wheel
Results 1 to 8 of 8
  1. Retrofitting RS4 Multifunction steering wheel
    Aug 2008
    Hi guys. I have a B7 2.0T saloon and I am planning to retrofit a RS4 Multifuction steering wheel. I currently have the normal 3 spoke s-line wheel. My question is I found on ebay a very nice looking D type RS4 MFSW, but wont extra parts be needed ??? Anything like control unit, new rings etc ????
    thanks
  2. Re: Retrofitting RS4 Multifunction steering wheel
    May 2008
    There is little point, you wont get the buttons working on an RS4 wheel in a non-RS4 car.
    You'd be better fitting a TT wheel (if its the flat bottomed bit you like?)
  3. Re: Retrofitting RS4 Multifunction steering wheel
    Aug 2008
    Ok, so say I find a S-line D-Type steering wheel, with the multifunction controls, what else will i need to retrofit/???
  4. Re: Retrofitting RS4 Multifunction steering wheel
    May 2008
    There are loads of thread about this. If you already have a MFSW then you need nothing. Otherwise you may or may not need a steering ECU. If you have cruise you probably wont need it if you dont have cruise then you probably will.
    Only way to be sure is to find out the steering ECU part number from the car.
  5. Re: Retrofitting RS4 Multifunction steering wheel
    Angus, Scotland
    Hi there,
    You would also need a new slip ring if you do not currently have a multi-function steering wheel as the standard one does not have the connections for the buttons.
    Paul
    A4 B7 S-Line 140 TDi
    Phantom Black, Bose Sound System, Arm-Rest, Retro-Fit DIS, Retro-Fit Cruise
    Fully registered Vag-Com/VCDS Hex-CAN
  6. Re: Retrofitting RS4 Multifunction steering wheel
    May 2008
    Quote Originally Posted by elPaulio View Post
    Hi there,
    Paul
    That depends on the age of the car.
  7. Re: Retrofitting RS4 Multifunction steering wheel
    Aug 2008
    thanks for the info guys. Just out of curiosity, what is the deference in the rs4 mfsw that makes it not compatible with the other cars ???? it has the standart buttons the rest cars use .... ....
  8. Re: Retrofitting RS4 Multifunction steering wheel
    May 2008
    Quote Originally Posted by unrealcy View Post
    No it doesnt. The genuine RS4 flat bottom wheel has buttons on it that control the trip computer. On a normal A4 these buttons are on the end of the wiper stalk. It also has the sport button that is useless on a non-RS4.
    There are no stereo control buttons on the RS4 wheel.
  1. Multifunction Steering Wheel
    By rallye in forum Golf MK5 - 2004 - 2009
    Last Post: 17-04-2009, 05:27 PM
  2. Multifunction steering wheel
    By fulcrum111 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 09-01-2009, 08:30 PM
  3. Question Multifunction steering wheel
    Last Post: 04-01-2009, 10:37 PM
  4. Multifunction Steering Wheel
    By rallye in forum Jetta MK3 - 2005 - 2013
    Last Post: 21-04-2008, 09:41 PM
  5. Multifunction steering wheel
    By no1spursfan in forum Golf MK4 - 1999 - 2004
    Last Post: 02-04-2008, 06:03 PM
