Thread: audi 80 temp guage not working
  1. audi 80 temp guage not working
    Hi guys.
    Having a problem with the temperature guage on my B4 80 2.0E sport.
    The problem is, it doesn't work.
    To be more specific, it will budge perhaps up as far as 25% up the guage if sat in traffic for a while but most of the time the needle doesn't even touch the guage.
    The heater seems to work fine.
    Any suggestions guys?
    Ian
    right. update.
    It was in the garage to have the temperature sender changed and this hasn't helped it in the slightest.
    anyone?
    Yorkshire
    Your thermostat in knackered.
    Your heater works as you think that 50 degrees is hot and your engine thinks that 50 degrees isn't hot.
    £10 from GSF for the thermostat.
    Get it done as you're also washing your bores with petrol, the Ecu will be delivering fuel to what it thinks is a cold engine. i.e. running with the choke on all the time.
    Quote Originally Posted by S2AVANT View Post
    not so good then eh.
    thanks for the help.
    Yorkshire
    Last time I did a thermostat it took me ten minutes. You will need a socket set and something to move the old thermostat as they like to stay put.
    any idea where it's located on the block? bit of a noob to be honest but if i can find it i should be okay if it's a straight swap.
    thanks.
    Yorkshire
    I think yours is on the bottom of the water pump.
    Makes that an 1/2 hour job.
  8. Audi 80 1.9TDI
    Mar 2007
    Hi, new to this sight. Just wondered if the temperature guage issue would be the same with diesels as well as petrols? Any ideas greatfully received.
    Buzz
  1. WATER TEMP AND OIL GAUGE NOT WORKING - A6
    By A6 trouble in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 08-03-2010, 04:24 PM
  2. audi 80 diesel temp guage
    By Busby in forum 80 - 90
    Last Post: 20-03-2007, 09:07 PM
  3. Audi A4 temp gauge
    By TomPetrilli in forum Audi A4 - Archive Topics
    Last Post: 18-01-2007, 11:35 AM
  4. Passat w/temp guage help
    By les in forum Passat - Archive Topics
    Last Post: 22-11-2006, 11:19 PM
  5. temp gauge not working
    By chrispey in forum 80 - 90
    Last Post: 28-07-2006, 02:46 PM
