Thread: Water Temp doesn't go past 60 / heaters are not working properly / loosing water every so often
  1. Water Temp doesn't go past 60 / heaters are not working properly / loosing water every so often
    Nov 2008
    Hi guys wonder if anyone can shed any light on this problem my dad is having with his Audi A4 1.8t.
    We had the water pump replaced 4 months ago but recently he has noticed the water temp doesn't go above 60 even after driving for a long time.
    When this happens the heaters don't seem to give out heat properly, e.g. when set at full heat, it would stay cold for a while before actually giving out some heat (this is on the motorway).
    He also said the low water level light came on a few weeks ago and again a few days ago.
    I've taken the oil cap off and have a picture of it below: This is from cold start and letting it run for 10 mins, the temp needle didn't move during that time.
    Any info would be much appeciated
  2. Re: Water Temp doesn't go past 60 / heaters are not working properly / loosing water every so often
    Drive the car for 15 mins.Press the upper radiator hose, and check if there is much pressure,if so, i think the head gasket is leaking,If there is no pressure then the thermostat is defect,and you have coolant leak somewhere.The system can be checked for gases with a coolant analysis liquid,which changes colour,if there is combustian gas in the coolant system.
  1. WATER TEMP AND OIL GAUGE NOT WORKING - A6
    By A6 trouble in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 08-03-2010, 04:24 PM
  2. Water Sensor Not Working On Low Water
    By alinux in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 11-08-2008, 11:18 AM
  3. Loosing water from the Rad
    By Maz in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-05-2008, 05:53 AM
  4. Audi A4 water temp Gauge not working
    By darlinj in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 23-04-2008, 04:24 PM
  5. New - Loosing Coolant water
    By pks68 in forum A8 - S8 - V8
    Last Post: 06-10-2006, 12:39 PM
