Thread: Window Switch Removal T5
  1. Exclamation Window Switch Removal T5
    Jan 2009
    Does anyone know how to remove the N/S window switch on a 2005 T5 Transporter. Is it the careful use of a screwdriver to prise it out or do you have to remove all the door card?
  2. Re: Window Switch Removal T5
    Remove upper door trim .
    Release connectors and pull off.
    Disengage locking lug and remove switch together with mounting frame out of upper door trim.
    Release locking lugs and remove switch from installation frame.
    I can send a diagram if you need it
  3. Re: Window Switch Removal T5
    Jan 2009
    Thanks for this.
    If its not too much a diagram would be great.
    Stuart.
  4. Re: Window Switch Removal T5
    Sep 2008
    Cornwall
    There are some door trim removal pictures here too.... http://www.brick-yard.co.uk/forum/fo...=238554#238554
  5. Re: Window Switch Removal T5
    Jan 2009
    Thanks T5 TDI, Kenny,
    The reason for removing the window switch is that my nearside window works off the drivers window switch, but not off the nearside window switch. The switch lights up with the lights on but does not work the window, so i'm assuming its goosed.
    What do you think?
    Thanks, Stuart.
  6. Re: Window Switch Removal T5
    Sep 2008
    Cornwall
    Could well be the switch but there are other possibilities too. The wiring to the switch or the comfort module faulty (it lives under the drivers seat and can suffer if it gets wet for any reason).
    Kenny is obviously a clued up VW tech so he is the guy to advise you.
  1. Electric Window Switch
    By j4s0n88 in forum Golf MK5 - 2004 - 2009
    Last Post: 03-12-2008, 10:11 PM
  2. Please Help window switch removal
    By smithysmith in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 23-09-2008, 07:51 AM
  3. Electric Window Switch
    By HenryCrun in forum Beetle 2000-
    Last Post: 03-09-2007, 09:52 PM
  4. Window switch on new beetle
    By chris01 in forum Archive posts
    Last Post: 05-04-2007, 05:53 PM
  5. Window switch replacement
    By Craigkirk in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 23-03-2007, 06:52 PM
