Thread: Coolant leak - looks to be in the bottom hose connection to the radiator
  1. Coolant leak - looks to be in the bottom hose connection to the radiator
    Feb 2009
    Hi all
    I've got a problem, and was hoping you may be able to offer some advice...
    My 02 passat recently started leaking coolant. I've replaced the radiator (the old one was quite corroded) but I've still got a leak - which looks to be coming from the bottom radiator hose connector. I've tried putting some grease on before making the connection, but it still leaks - about 3 drops a minute....
    Is it possible to get replacement seals for the hose? Is there anything else I can try?
    After spending ages getting the bumper & everything else off to change the radiator, I don't want to take it to a garage and have to pay them to fix it!!!
    Harvs
  2. Re: Coolant leak - looks to be in the bottom hose connection to the radiator
    Norfolk
    Some garages won't replace a radiator without replacing the hoses as well. Perhaps that is a clue
  3. Re: Coolant leak - looks to be in the bottom hose connection to the radiator
    Feb 2009
    I don't want to pay a garage for a new hose and for them to fit it. I want to pay a couple of pounds for a new seal ring and to fit it myself.
    Please can anyone tell me if it's possible to buy the seal ring / or if there's anything else I could try?
  4. Re: Coolant leak - looks to be in the bottom hose connection to the radiator
    Jan 2009
    Gloucestershire
    I replaced my radiator last week and it came with the new seals in the box!
    you should be able to get them from a motor factors
  5. Re: Coolant leak - looks to be in the bottom hose connection to the radiator
    Norfolk
    You can buy the seals from vw dealers. Not every seal for every model is available but most are.
  6. Re: Coolant leak - looks to be in the bottom hose connection to the radiator
    Feb 2009
    Great, thanks guys. I didn't realise that the vw garage may sell the seals seperately. I'll give them a call.
    Many thanks for your help
    Harvs
  1. Bottom hose cold
    By Grant620 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-12-2008, 04:17 PM
  2. Overheating, Hot top hose, cold bottom hose...ECT?
    By 1.9 TDI Sharan in forum Touran - Sharan - Caravelle
    Last Post: 26-04-2008, 11:28 AM
  3. Where can I get a spring clip for the radiator bottom hose ?
    By JonE in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-08-2007, 04:21 AM
  4. Replacing bottom read hose pipe
    By SpanishGolfGTI in forum Archive posts
    Last Post: 15-07-2007, 07:32 AM
  5. Stone cold bottom rad hose...
    By colifeashots in forum Passat - Archive Topics
    Last Post: 24-02-2007, 04:16 PM
