Thread: eratic heater blower
Results 1 to 8 of 8
  1. eratic heater blower
    Mar 2007
    help,the blower on our heater works when wants to,usually comes back to life with a smack to the dashboard.when does work speed eratic.thanks in advance
    Dec 2006
    Sounds like a flap motor has failed.... when you say it come back on eratic.. is that even when you change the speed setting it stays the same??
    RiCKT
    Aug 2006
    Devon, UK
    Could be the bushes in the motor.
    Passat Sport Estate 2001 1.9 TDI PD
    100k miles
    Nov 2006
    Swampyland, UK
    Quote Originally Posted by jack View Post
    Don't forget that the B6 A4/S4 blower fan automatically adjusts itself.
    Mar 2007
    thanks,yes the blower is eratic at all speeds.sometimes you get no blower at all, thanks
    Mar 2007
    Motor bushes are going quickly.
    Remove motor and TURN BUSHES 180 DEGREES you will get a few years outa um yet.
    S.Yorkshire
    I had the same problem on my A4.. Cost a shed load to replace the motor (nearly 300 quid all in!!!) If you can get the motor out and mess with the brushes to get it workin you might save a shed loada money!!
  8. Re: eratic heater blower
    I realise that this is quite an old thread but if you are looking for motor brushes these may be what you are looking for.
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...MESO:IT&ih=009
    I had problems with my Passat blower, it would work fine sometimes and then other times it wouldn't work at all. Removed the motor and fitted a set of these and its now working perfectly.
  1. Sharan - Heater Blower Motor Brushes
    By Paul Sharan in forum Touran - Sharan - Caravelle
    Last Post: 18-02-2009, 10:39 PM
  2. clicking climate control/eratic airflow
    By Alexandram in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-12-2007, 03:42 PM
  3. Heater Blower
    By Turkster in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-05-2007, 03:05 AM
  4. NO HEATER BLOWER
    By EMILY in forum Passat - Archive Topics
    Last Post: 23-01-2007, 05:38 PM
  5. Blower
    By scutter in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-12-2006, 05:22 PM
