Thread: Golf brake failure
  1. Golf brake failure
    Feb 2009
    Hello!
    The brakes on our son's 1999 Golf Gti failed the other day: pool of fluid appeared under rear os wheel.
    When the garage looked at it, a compression washer had corroded away. This turned-out to be made of aluminium. This one, and the other side, have now been replaced with copper.
    The mechanic said he had come across aluminium ones before on Golfs. I've owned, and, until recently, repaired our VWs for many years. I've never come across an aluminium compression washer before. It sounds like an obvious route to trouble.
    Has anyone else come across this, and the reason for changing from copper?
    Mervyn
  2. Re: Golf brake failure
    Aug 2008
    Wigan
    9 Post(s)
    This has been on the forum recently; my guess is VW have saved a few pfennigs on each car by using a cheap aluminium washer instead of a decent quality copper washer.
  3. Re: Golf brake failure
    Feb 2009
    Many thanks, batteryman, for the reply.
    I did a search before I posted, but it did not reveal the thread you refer to.
    It seems madness to me not to use copper in this location - asking for trouble!
    Thanks again.
    Mervyn
  1. Please Help Brake Light Failure Indicator shows brake bulb fault but bulbs are ok
    By IrlA4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-02-2012, 12:56 AM
  2. TDI 130 Brake Failure
    By dirtyderv in forum Bora - 1998 - 2005
    Last Post: 26-05-2009, 10:05 PM
  3. Brake failure warning
    By PeteK in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-12-2008, 06:20 PM
  4. Possible brake failure?
    By eugoogoly in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-08-2007, 11:44 AM
  5. A6 brake failure
    By interim in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 27-01-2007, 08:20 PM
