Thread: 1st Gear
  1. 1st Gear
    Feb 2009
    Hi
    i bought a passat tdi 130 (2003) 60,000 miles, earlier this week and believe there is an issue with gearbox or clutch???
    When stationary it is difficult engaging 1st gear. it doesn't matter whether i have just started the journey or 3 hours in, it is still as difficult. there is quite a lot of resistance.
    Any help would be great before taking car down to local garage.
    Thank you
  2. Re: 1st Gear
    Jan 2009
    towcester northants
    1st gear is tight on these my 1.8t is tight and has done 83000mls i usually engage 1st as car is still moving slightly
    or if stationary select 2nd then 1st
  3. Re: 1st Gear
    Norfolk
    If it goes into reverse ok the clutch is ok.
  4. Re: 1st Gear
    Feb 2009
    it goes into reverse ok yeah. thats one worry off my mind.
    will see what the garage says
    thanks a lot
  1. Mk4 Gear Knob Gaiter - Gaiter to Gear knob connection
    By frost015 in forum Golf MK4 - 1999 - 2004
    Last Post: 20-03-2009, 09:08 PM
  2. Question Ideal gear changes in GT TDI for MPG + 6th gear?
    By tomjj in forum Golf MK5 - 2004 - 2009
    Last Post: 18-09-2008, 06:08 PM
  3. Question Rattle Clunk sound from gear box when changing gear?
    By jasonocallaghan in forum Golf MK5 - 2004 - 2009
    Last Post: 27-06-2008, 12:20 AM
  4. Help Please! 1st gear jumps out of gear
    By TollyTDI in forum Toledo
    Last Post: 17-06-2007, 07:50 AM
  5. Gear jumps out and non smooth gear changes
    By RIZWAN180 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-06-2007, 09:45 AM
