Thread: Gearbox oil change interval?
Results 1 to 10 of 18
  1. Gearbox oil change interval?
    Feb 2007
    Leicester
    Does anyone know the interval for a 2001 A4 TDi 115? Also, does anyone know what type to use to try and improve the gearchange quality.
    My car has done 106k and although the change is not too bad there is a bit of awkwardness into 2nd. Maybe this is just normal on the A4?
    Thaks for your help.
    Dec 2006
    Auto or Manual??
    I guess manual... Teutonic_Tamer will pull me on this,..... bit i thought the oil in the manual was meant for life and not part of any service?? i know it can be changed with the correct tool....
    Teutonic_Tamer - can you confirm
    RickT
    Nov 2006
    Swampyland, UK
    As Rick pointed out, we need to know weather your box is auto or manual?
    The transmission components are supposed to be filled for life (with the exception for Multitronic [40k oil and filter], DSG [40k oil and filter], Haldex [20k oil, 40k oil an filter]).
    However, common wisdom would deem any transmission fluid be changed anywhere between 40k and 80k miles. Afterall, on a conventionally mounted gearbox, and separate rear final drive unit, the oil change is relatively easy and straightforward, and even the average home mechanic could do it, providing the correct vehicle lifting equipment, and stands were used.
    The fluid is OEM only - no aftermarket alternatives should be used!
    If you do wanna change the fluid, post again, and I'll add some tips for diagnosis.
    HTH, rgds
    Feb 2007
    Leicester
    Sorry, yes it is a 5 speed manual gearbox. I would like to know how to change the oil if you could tell me. Thanks for your advice.
    Dec 2006
    Teutonic_Tamer - On my B6 its like a large torque bolt, with a pin in the middle.. to stop you using own own torque!! (Thats if i remeber right!!)
    Any idea where i can get one... i surffed ebay and contacted a few local trade suppliers i know a while back but didnt find any.
    Nov 2006
    Swampyland, UK
    Quote Originally Posted by RickT View Post
    Do you mean a 6 point star shaped female socket hole, with a nipple like post in the centre? If so, then that is a Torx security screw/bolt, and a Torx security, or "tamperproof" bit or driver will be needed.
    http://www.cromwell.co.uk/searchform - use "Torx" in the description box.
    Or find a local Draper, or Richmond tools stockist. I've got bit sets from both, but I'd imagine the drain and filler plugs to be quite a bit larger than my offerings!
    Or if you really want to flash the cash, a Snap-On man in a van.
    Rgds
    Nov 2006
    Swampyland, UK
    Quote Originally Posted by wid77 View Post
    Look on your car data sticker, either in your service book, or under the boot carpet, and find the three digit gearbox code, something like 012, or 01W.
    Then take a shufty here: http://volkswagen.msk.ru/
    Go Transmissions, and look under Passat B5, as they shared many components with the B6 A4 range.
    Feb 2007
    Leicester
    Quote Originally Posted by Teutonic_Tamer View Post
    In the vehicle data section of the service book it says
    gearbox: M5S
    gearbox code: DUK
    Not sure what these mean apart from presumably 'Manual 5 gears'. Nothing like the codes that you say though unless i'm looking in the wrong place. Thanks.
    Oct 2006
    Is the Passat engine longitude then like the A4 as I thought all the VWs were transverse even the Golf R32 with 4wd.
    I think my box code is GBD, i'll have to check.
    Nov 2006
    Swampyland, UK
    gearbox: M5S
    gearbox code: DUK
    OK, that's the correct info.
    The "M5S", as you correctly guessed, simply means Manual 5 speed.
    The code of "DUK" is a little harder to work out for the un-initiated - however, I can confirm that that code translates into an 012 gearbox!
    Just for info, all VW/Audi gearbox codes are converted into build types, and you can confirm for yourself from this handy PDF (right click > save target as) http://volkswagen.msk.ru/vw_doc2/trans/vw_gkb-type.pdf.
    The actual manual for your 012 box will be found here: http://volkswagen.msk.ru/index.php?p=page05_012.
    HTH, rgds
  1. Golf 2 litre cambelt change interval
    By PJS in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 29-05-2007, 08:10 PM
  2. Multitronic gearbox Oil Change
    By Seanious in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 03-04-2007, 09:13 PM
  3. cambelt change interval
    By jezzaxt in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 30-09-2006, 10:09 AM
  4. Correct cambelt change interval for 1998 Passat?
    By cmman127 in forum Passat - Archive Topics
    Last Post: 02-03-2006, 10:13 AM
  5. 89 G Reg Passat Cam Belt Change Interval
    By PeterGittings in forum Passat - Archive Topics
    Last Post: 28-02-2006, 08:25 AM
