Thread: water in foot well
  1. water in foot well
    Feb 2007
    hi just got a passat and the passengers footwells and rear passengers footwell is completely swimming and the comfort control module is shot now would any one be able to give me a some advice on sorting this problem out the water is comming in from the pollen filter sill i think as all the drains are clean on the bulk head.
    Feb 2007
    Hi, try here for starters.
    https://www.vwaudiforum.co.uk/forum/s...ght=water+link
    There is a lot written on this problem and you will have to do a search for other posts to help you out.
    Good luck
    Fozzie!
    Dec 2005
    Try the following. Tells you in great detail what to do.
    http://www.weirdlittlebiscuit.com/passat/leak/
  4. Water Ingress
    Hi, I had the same problem, re-sealed the pollen filter housing, cleaned the bulkhead drain plugs, still water coming in.
    Hose pipe check on the front passenger door, showed that water was breaching the door seal, there are two rubber strips under the door, water was getting into the door via the door mirror, running down between the inner door and thr trim panel, onto the front rubber strip and into the footwell.
    Sealed the hole in the door where the mirror connects to the door.
    Problems solved.
    Dec 2006
    How about this. Over the weekend I left the passt on the street. It was parked down slope (a %4 grade) and half on the pavement. Drivers side was on the road. I get in on Monday morning and guess what!
    Water in the driver's footwell! Not a huge amount but enough to worry me. Luckily I have rubber mats so I was able to dump most outside. I checked the battery drain, it was fine. the one behind the master booster..clogged. plenty of grunge back there, but the rest was clean. I also splashed water on the bonnet cable grommet.looked okay. Haven't checked the pollen filter yet.
    That was the night we got snow so wonder if that caused this. I never had this issue before. who thought up the design of these components? My 11 year old Mazda has never had any water ingress in its life. Maybe VW should take a couple of designs off them?
  1. oil in water
    By christy in forum Archive posts
    Last Post: 06-08-2007, 05:45 PM
  2. Oil in water 2001 130 TDI
    By Sadbob in forum Passat - Archive Topics
    Last Post: 25-01-2007, 08:29 PM
  3. Water in car
    By scottishcruiser in forum Passat - Archive Topics
    Last Post: 15-01-2007, 08:09 PM
  4. Golf Mk 4 - Water in Rear Foot Well
    By Bectism in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 30-11-2006, 02:27 PM
  5. Water in Foot well
    By andrew steele in forum Chat - Completely Off Topic
    Last Post: 23-11-2006, 09:22 PM
